vats module
Old Jan 31, 2009 | 02:25 PM
joescvette's Avatar
joescvette
Default vats module
on a 1988 anna. does anyone have picture of a vats module, & instructions on how to get to it? I pulled out a module but not sure if its the right one. THANKS
Old Feb 1, 2009 | 12:24 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here's an 87. It is the large square object in the center. I got mine from www.vette2vette.com
Just give Jason the code from your key and he can get you a used one. Mine solved my 87's starting problem. Just pull the front of the dash apart to get to it. I replaced my bread box at the same time with a flat panel. In order to get to the upper bolts of the bread box mount you have to remove the upper dash pad.
Old Feb 1, 2009 | 11:51 AM
joescvette's Avatar
joescvette
The photo was great, now I know what I'm looking for THanks
To vats module
