engine replacement
Old Jan 31, 2009 | 11:19 PM
gt0069's Avatar
gt0069
1st Gear
Default engine replacement
Have a 94 was wandering if anyone has ever dropped in
a custom engine that wasn't a LT1 block but a block off
a earlier model.
Old Feb 1, 2009 | 02:37 AM
rodj's Avatar
rodj
You aren't going to use the original intake on anything but a LT1 / LT4 heads and block.
If you don't use the intake and opti spark then you can't use the original computer and wiring ;
so you need custom wiring and computer or a carb in which case anything that fits.
LSX conversions are popular.
Old Feb 1, 2009 | 09:25 AM
Iroc57's Avatar
Iroc57
You can put in anything that fits(even something that doesn't) with a little extra work but do you want to?
If you are going for a driver it is much better to go with the correct engine. If you are going for the challenge or shock value then a BBC or LS swap is cool but to just go to an earlier SBC doesn't make much sense.
Just my $.02
To engine replacement
