Locking Lug Nut Issue
Old Feb 3, 2009 | 10:16 AM
janarvae's Avatar
janarvae
Originally Posted by Andrew
Yep, with the tool I described works the same. You tap it on with a hammer, then twist and it bites into the nut. I used a 3/4 drive socket on the C3 and they came off just like any other lug. The locking nut is destroyed, but that is usually not a concern. Car thieves that are pros will have them off as easily as regular. What will really make you angry, lock your keys in the car and have someone get them out. Takes less than 30 seconds if they are good.
A family member just locked my keys inside 2 weeks ago. A locksmith with an air wedge and a bent metal rod that was stiffer than my clothes hanger contraption unlocked it manually. The alarm did go off though when we finally opened the door!
Old Feb 3, 2009 | 10:43 AM
Andrew's Avatar
Andrew
How long did it take? I locked the keys in our 300C, took the guy under 30 seconds and handed me a bill for $50. How would you like to make $6,000 / hour???
By the way, I'll get a picture of the removal tool tonight.
Old Feb 3, 2009 | 10:51 AM
janarvae's Avatar
janarvae
Well, first he tried to slim-jim it, but he couldn't. So he carefully hand-pumped an air wedge (like the blood pressure cuff hand pump) against my new weatherstripping, stuck a thick, bent rod in there, and pushed the manual unlock button. Maybe a minute for the air wedge technique!
-Jonathan
Old Feb 3, 2009 | 12:36 PM
KBRVETTE93's Avatar
KBRVETTE93
I took it to Sears Automotive. They used one of the tools described on this thread. 2 minutes, $24.
Dealership had no keys. Said that one of the techs (no longer there) had a full set.
Sears is good. Craftsman Tools.
Old Feb 3, 2009 | 07:31 PM
enventr's Avatar
enventr
Originally Posted by davidarnesen
On the wifes mustang........
I took a socket and hammered it onto the lock and then took a breaker bar and simply took it off
i did this on the shoulder of the freeway when she had a flat
This is the easiest way-If you dont want to do it yourself then take it to your local gas station-they will have it off in minutes
Old Feb 3, 2009 | 07:41 PM
Andrew's Avatar
Andrew
Here is the tools that I was describing.
Old Feb 3, 2009 | 07:42 PM
davidarnesen's Avatar
davidarnesen
yeah it only took me about 5 min with the socket and the B.F.H
Old Feb 4, 2009 | 12:00 PM
KBRVETTE93's Avatar
KBRVETTE93
Is that similar to a hammer, only slightly larger?
Thanks for the help guys!
Old Feb 4, 2009 | 02:24 PM
davidarnesen
its acually quite a bit larger in some cases then a normal hammer.
Old Feb 5, 2009 | 11:14 AM
KBRVETTE93's Avatar
KBRVETTE93
...what I would give, to have one THAT SIZE!
I have heard of this legendary "B.F.H'"... but, (until now that is) I confess I really thought it was...well.. .
Old Feb 5, 2009 | 12:19 PM
Greg0u812's Avatar
Greg0u812
That would be a GREAT way to make $6,000 / hour!!!!
But where are you going to find 120 idiots in the same location with keys locked in the car.........Oklahoma........Arkansas???
Yeah, I guess you don't have to take into consideration the drive time to and from the location, checking out the car to make sure what tools would be the best option, etc.....
LMAO!!!!!!!!!!
That is one BFH!!!
Funny, I just said that a couple of nights ago after renting a particular movie from a.........umm.........well....... special type of movie rental store.
