Just find a picture on the forum of a Vette with the hashmarks applied and try to duplicate it. If you use the soapy water like suggested earlier you can move them around till you get them where you want them.
If you can wait till next week you can measure off mine. I just put them on. Factory set with the template. I sorta distroyed the template during install, otherwise you could have it (if you could call it a template).
I put mine on some time back. Just like suggested, use soapy water and you can slide them around until you get them located, then use a plastic straight edge and squeze out the water, wait until dry and you are done, about an hour in all. Good luck. Sid.
im waitin for my hash marks too, i was gonna use "Bug & Tar Remover" to clean the area before i apply, is that a good idea? It says its safe on all painted surfaces, but im just makin sure. thanks-AJ :crazy:
