Optispark Install With Pics
Tools needed.
Flathead screwdriver MAF housing
14mm socket for 6 water pump bolts and 2 coil bolts.
16mm socket for 3 crank pulley bolts and pulley belt tension.
Swivel and extension for water pump.
Needle nose pliers for radiator peacock.
C clamp for hoses.
Drive the Car on boards.
Disconnect the battery.
Jack Up the front. I use a board and jack stands.
Drain the coolant.
Maf housing and sensors.
Maf out of way and fuel rail cover.
Radiator hoses came next. I used a C clamp to remove them.
I remove the coil so water pump gets out easier.
Water pump off.
Taking belt off and removing crank pulley same time.
Crank pulley off and optispark.
You might want to consider doing a tb bypass while you have the coolant drained. Replace the upper rad hose with one for the '95 (AC/Del #24408L) and the heater hose pump-to-surge tank with that from a '95 (AC/Del #18140L). Then a couple caps for the tb open ports and it all makes for a nice, clean install.
Need to finish it now....
Last night I was looking for a detailed write up with pictures on a 1.6 rr swap. I couldnt believe I could not find one with it being such a popular mod. I guess I may have to be the first. Same goes with a cam swap. There was one with good pictures but there were several steps/pictures and detailed info missing.
Since I've done it before my crank pulley can wobble off by hand.
http://www.vetteweb.com/tech/vemp_07...e_install.html
I like keeping the car original, but the NCRS sickness makes me that way!
http://buy1.snapon.com/catalog/item....re&dir=catalog
