LED Gill Lights
It's pretty easy really. I just tied into the front side marker lights on each side of the car with 16 GA wire. I used a 12" LED strip and cut it in half. I didn't trust the sticky back on the strips so I used some trim adhesive to glue them on with. I painted the inside of the panel with aluminum paint for reflection. The glow would probably be softer is it was black though.
It would probably end up costing about the same as the strips if you were to build them yourself, especially if you buy the color leds from somewhere else other then radio shack via the internet. You could get them for like 50 cents each, or even cheaper. It would be cheap to stick a small string of them in a clear tubing to make them weather proof.
You could simply mount 3 ***** somewhere inside the car and adjust each color manually to get millions of colors out of them. All 3 let up at the same brightness would give you a white light.
If you use a microcontroller you could make the colors change automatically over time, just slowly fade from color to color, or maybe even make them change based on events. Acceleration, breaking, music, temperature, brightness of outside lights, ect...
Might have to be careful about going full blue and red
Don't want to appear to be impersonating a cop car.I plan on doing this type of thing myself since I have recently started learning how to program microcontrollers and really learn how electronic circuits work.
Go for it......that may be a little radical for me though.
I just wanted a slightly different look. Besides, electrical stuff is like Greek to me.
