LT-5 oil filter question
Old Jan 24, 2002 | 02:34 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default LT-5 oil filter question
Many of us L-98, LT-1 and LT-4 owners are in the habit of "priming" a new oil filter for use by pouring a little bit of fresh oil into it before installing. It's easy on engine's like ours with bottom-mounted filters.
However, the LT-5 in the ZR-1 features a top-mounted oil filter. I am wondering if it's possible to prime an oil filter with this type of configuration in a similar manner? :confused:
[Modified by onedef92, 1:35 PM 1/24/2002]
Old Jan 24, 2002 | 11:22 PM
Canzr1's Avatar
Canzr1
Cruise-In I Veteran
Default Re: LT-5 oil filter question (onedef92)
I "wick" my filter, but do not fill it with oil before installing it. Now, when it comes time to remove the filter, none will leak out upon removal until the filter is inverted, after that it will drain out. :cheers:
Old Jan 24, 2002 | 11:57 PM
Justin1984's Avatar
Justin1984
Default Re: LT-5 oil filter question (Canzr1)
:confused: :confused: could you re-explain that? I don't understand. Are you saying the filter is mounted on the top of the LT5 block pointed downwards?
Old Jan 25, 2002 | 03:24 AM
LotusV8's Avatar
LotusV8
Default Re: LT-5 oil filter question (Justin1984)
Yup its' mounted on the top of the block pointing downwards.
Mike
Old Jan 25, 2002 | 03:29 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: LT-5 oil filter question (LotusV8)
:confused: :confused: could you re-explain that? I don't understand. Are you saying the filter is mounted on the top of the LT5 block pointed downwards? Yup its' mounted on the top of the block pointing downwards.
Mike
Look in the lower left hand center corner of this pic, you'll see the black filter.
[Modified by Jeffvette, 1:29 AM 1/25/2002]
Old Jan 25, 2002 | 05:29 AM
GlockLT4's Avatar
GlockLT4
Default Re: LT-5 oil filter question (Jeffvette)
man.. that's the best picture you could come up with! :confused: :confused: :crazy: That oil filter in your picture looks like a black head or something! :U
:D ..
Try this one...
[Modified by Glock'94, 3:47 AM 1/25/2002]
Old Jan 25, 2002 | 05:42 AM
Jeffvette's Avatar
Jeffvette
Default Re: LT-5 oil filter question (Glock'94)
:D ..
Go fix your PCM :lol: :seeya :jester
Old Jan 25, 2002 | 05:47 AM
GlockLT4's Avatar
GlockLT4
:D ..
:lol: :lol: :lol: :lol: Fine I will :seeya :seeya :jester :p:
Old Jan 25, 2002 | 09:01 AM
onedef92's Avatar
onedef92
IOW, what you're saying is gravity causes whatever oil that's pressurized inside the filter to ebb back into the crankcase after you shut the LT-5 engine off.
And, after you "wick" your replacement filter, you experience a little fresh oil run-off as you invert the filter to screw it on. I guess a shop towel is all you need to manage this spillage, right? :yesnod:
[Modified by onedef92, 8:01 AM 1/25/2002]
Old Jan 25, 2002 | 02:47 PM
mike72's Avatar
mike72
the ZR1 filters have a check valve in them to keep the oil from running out of the filter once it is in there.
Old Jan 25, 2002 | 03:00 PM
GlockLT4's Avatar
GlockLT4
Default Re: LT-5 oil filter question (mike72)
:confused: :confused: That just sounds weird .... oil should go in and come out of a filter :jester
Old Jan 25, 2002 | 03:11 PM
mike72's Avatar
mike72
weird but true.
Old Jan 25, 2002 | 03:17 PM
GlockLT4's Avatar
GlockLT4
I bet they charge an extra $10 for that filter because of that lol!
Old Jan 25, 2002 | 03:47 PM
Kale's Avatar
Kale
<BLOCKQUOTE>code:<HR><PRE>
FILTER-OIL for a
1990 CHEVROLET CORVETTE ZR-1
Normal Stock
Special Order
Not Available
Item Part No.
Warranty Core
Value Unit
Price Availability
Store Web
DEUTSCH D401 $2.86
BOSCH 3401 $5.99
MOBIL_1 M1-207 $11.99
FRAM PH3985 $3.49
K&N HP-2007 $14.99
</PRE>[/QUOTE]
Old Jan 25, 2002 | 03:51 PM
GlockLT4's Avatar
GlockLT4
Default Re: LT-5 oil filter question (Smash)
:eek: :eek: That's pretty good!
Old Jan 25, 2002 | 04:13 PM
onedef92's Avatar
onedef92
So, after you "wick" your replacement filter, you normally experience a little fresh oil run-off as you invert the filter to screw it on, right? Again, I guess a shop towel is all you need to manage this spillage, right?
:confused:
Old Jan 25, 2002 | 04:34 PM
jerryv's Avatar
jerryv
Since it's top-mounted, it probably doesn't 'sump' oil, so it wouldn't matter much whether it was primed or not. The only reason to fill them on other engines is to avoid the few seconds of running dry while the oil pump fills the filter.
To LT-5 oil filter question
Old Jan 26, 2002 | 01:02 AM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
Default Re: LT-5 oil filter question (Jerry Velders)
That's the first time that I've heard that about the ZR-1 filter. Learn something new every day. Thanks :cheers:
[Modified by GWH, 11:03 PM 1/25/2002]
Old Jan 26, 2002 | 01:34 AM
SPEEDEMON's Avatar
SPEEDEMON
Only some of the filters have the check valve but not all. The AC Delco filter does not have a check valve. I use the WIX filter, which they also make the NAPA filter which is the same filter, and they do have the check valve. On the LT-5 engines after draining the 9 quarts of oil you still have about 2 quarts left in the crankcase in which some of us don’t need to prime the filter. Priming the filter makes a mess on the engine in which you can stain the finish of the engine.
Old Jan 28, 2002 | 09:24 AM
onedef92's Avatar
onedef92
Default Re: LT-5 oil filter question (SPEEDEMON)
Thanks, SPEEDEMON. You nailed it! :smash: That's the info. I was looking for! Great looking Z's guys, all! :cool:
