Head Gasket Question
My question is should I replace the right side head gasket as well. There is no sign of failure and the plugs and compression are fine. I was wondering if I can leave it alone since I don't want to mess with that other exhaust manifold and all that additional work.
Any information would be appreciated.
Thanks!!!!
L98's are known for blown head gaskets.
Could you explain this, please?
I have an 89, and my compression checked out to spec. I have noticed some oil in the coolant, but no coolant in the oil.
From Left to Right: 1234
From Left to Right: 5678
Typical failure for the reasons GM gave us back in '90, though I'd guess yours may have blown before (given the mileage).
There were plenty of owners with the same issue when I joined the Forum. Many reported that they found evidence that the gasket had been leaking for some time before discovering the problem. Mine probably started leaking at 25,000 miles or less and finally let loose at around 50,000 miles. My theory is that it always occurs at the rear of the heads due to the coolant restrictors in the intake gaskets. That allows more coolant to sit around there longer and once electrolysis takes over, it eats away the head gasket (in amazingly short time). To prevent it from happening, you need to make sure that no dissimilar metals come in contact with whatever coolant you're using so be sure to use pipe thread sealant on any sensors (CTS, Aux Fan Switch etc) and the thermostat bolts.
My 89 has 90K miles on it. I have no apparant coolant in the oil. It doesn't overheat. Looking at the pics of my spark plugs above, do any of them look like a coolant leak? I know they all look like they are carbon fouled. So, I would assume if one was leaking, I should have one or two spark plugs that are clean.
My compression test was good. Though, there is alot of crud I noticed in the radiator fines. Does this look like Galvanic corrosion, or maybe just those sealer pellets from the dealer?
The only other thing, is it seems the coolant system holds pressure real good. The other day I hadn't driven it for a couple of weeks, and with the engine still off, I pulled the radiator cap lever to remove the cap, and got a couple of burps in the overflow tank.
Though, when I tried to do the combustion leak tester, I wasn't able to because coolant kept squirting out the radiator opening. I removed a third of the coolant on the cold engine, started it and let it get up to temp. Then I noticed coolant was gushing out. I'm guessing that doesn't sound good?
