Gas Disposal?
Old Feb 20, 2009 | 03:22 PM
Donne Trav's Avatar
Donne Trav
Default Gas Disposal?
Anyone out there ever had to dispose of gas/fuel in the past? Where
did you "dump" it or get rid of it? What is recommended. I'm sure
there would be a concern for safety. Any advice would surely be
welcome. Thanks
Old Feb 20, 2009 | 03:52 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Put it in a gas safe container first. Check with the city, they may have a place where you can take it or at least maybe they can give you some guidance on how to dispose of it properly. The Fire Department also may give you some insight. Here the city of Columbia, Mo has a drop off point you can take hazardous waste to. Look in the phone book under hazardous waste. just some ideas.
Old Feb 20, 2009 | 03:57 PM
Steve20's Avatar
Steve20
when it's not a lot of gas, I put it in the oil change pan in the and let it sit in the sun to evaporate--better than ending up in the ground water
Steve
Old Feb 20, 2009 | 04:37 PM
Larry/car's Avatar
Larry/car
Used it up in my tractor. Even old fuel will burn if mixed with new, though maybe not as powerful.
Old Feb 20, 2009 | 04:48 PM
Steve20's Avatar
Steve20
I'd be concerned burning the old fuel may cause the rings to coke/stick.
Happy it worked for you though.
Steve
Old Feb 20, 2009 | 04:52 PM
ottawabarber's Avatar
ottawabarber
unless it is like goo it should be fine for lawnmowers etc.
Evaporate is why they have the large nozzles at the pump
Evap = ozone
Old Feb 20, 2009 | 05:02 PM
TGReaper's Avatar
TGReaper
I have always mixed old gas with new and burned it in the lawn mower,ATV,and small tractor. It even works fine if the old gas is mixed ie outboard gas.
Regards:C4
jsls0130's Avatar
jsls0130
Most parts stores will take it. Try calling auto zone or advance auto.
Old Feb 20, 2009 | 05:10 PM
Nathan Plemons's Avatar
Nathan Plemons
How old is it? The stuff's too expensive not to use. Surely you've got a lawnmower or something that can use it.
Old Feb 20, 2009 | 05:35 PM
Frizlefrak's Avatar
Frizlefrak
Regards:C4
Works just fine. No point in wasting it.
Old Feb 20, 2009 | 06:44 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Just dig an open pit, and fill it up w/old gas.
Light and run. BURN BURN BURN
Old Feb 20, 2009 | 10:02 PM
Donne Trav's Avatar
Donne Trav
Yo "Humorous One", I ain't tryna get locked up!
Old Feb 20, 2009 | 10:10 PM
Donne Trav's Avatar
Donne Trav
Regards:C4
Yo Guys, as stated in a recent thread of mine, I have suspected bad
gas (water/dirt) in the tank that may be causing the roughness I've
encountered the last 2 weeks. I'm down to the "reserve" tank or about
2 bars so I thought about siphoning the remainder gas/water and
disposing of the stuff/.
Old Feb 20, 2009 | 11:23 PM
pologreen1's Avatar
pologreen1
Some people take the old age of gas too serious. I have used old gas even untreated, in all kinds of vehicles, and tools.... Unless it is varnish it should be fine if you burn it up right away. Unless it is years old.
Old Feb 21, 2009 | 11:30 AM
TGReaper's Avatar
TGReaper
I'm just cheap,even for 2 or 3 gal.I would let the water / dirt settle out, in a closed container then syphon off the good stuff and use it in something.
Regards: C4
Old Feb 21, 2009 | 11:48 AM
pologreen1's Avatar
pologreen1
You can see why we drive c4's LOL can't waste a bit of gas.
Old Feb 21, 2009 | 04:52 PM
the blur's Avatar
the blur
find a cement parking lot and just spill it. it will evaporate very fast.
I'd use 1 gallon at a time with 5 gallons fresh gas. it won't hurt anything.
To Gas Disposal?
