Headlight motor advice???
Old Feb 23, 2009 | 11:53 AM
dlb435's Avatar
dlb435
Default Headlight motor advice???
OK, I just finished changing the grears in my headlight motor....again.
I know one option of prolonging the headlight motor life is to just drive in the day time.
Second option might be to raise and lower the lights by hand.
Any good advice from long time owners about this issue?
Old Feb 23, 2009 | 05:09 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I would be curious as to how long in between you replaced them. One option would be to go with the brass replacement parts, if you haven't already. They should last a long time. One other thing I have never heard anyone mention is making sure you keep them lubed. I don't know how much you drive your vette but the single one thing that causes gaskets to fail or any moving part is not using it. They have a tendency to gum up and/or dry out. But a headlight motor should last a long time when it's rebuilt. Might be something else that caused this for you.
Old Feb 23, 2009 | 05:24 PM
dlb435's Avatar
dlb435
I did have some trouble with the headlight hitting a brace, but I have fixed that problem. The car gets driven daily so there are no issues with parts drying up from getting no use.
I guess that extra strain did more damage than I thought.
Old Feb 23, 2009 | 05:29 PM
RetiredSFC 97
I couldn't tell you for sure that's what it is but I just replaced one of mine, and I won't tell you what a bonehead thing I did, but mine was also hitting something and now my new motor is making a whining sound. I think it just got hung up a little and started stripping the gears. So I ordered a new motor for when that one finally dies. But that is exactly what happened to me. It doesn't take much to strip those plastic gears.
Old Feb 23, 2009 | 05:35 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Use the much lighter plastic headlights that are available at auto suppliers such as NAPA. If you heft a glass one and a plastic one in each hand at the same time you can really feel the difference.
This is one of Gordon Killebrew's tips.
Old Feb 25, 2009 | 01:00 AM
newbecorvetteguy's Avatar
newbecorvetteguy
How much time is passing between problems? I drove my '87 daily for 4 years without stripping a gear. One quit working due to poor contact at a limit switch. A points file took care of that. If you're going through a lot of gears I'd suggest looking for some sort of resistance. If you for some reason turn on and off the lights making the motors change direction mid cycle would probably do it. The plastic gears act like a fuse. Though metal gears might sound like the best solution, the consequenses might be the case breaks instead of a gear. Just suggesting that you try to diagnos the problem before concluding the problem is plastic gears.
Old Feb 25, 2009 | 09:30 PM
Dave Ditner's Avatar
Dave Ditner
Default Headlight gear
Just replaced the delrin pins in one of the headlights of my wife's 95. The biggest piece of the parts internal to the gear was about the size of a bb. I have no idea what the original parts looked like. I found out that an electronic control senses motor amperage increase as the motor headlight comes in contact with the stop and shuts the motor off. I was surprised at the amount of load there is on the headlight at either end position. Try turning the manual **** and see how many turns you go before the headlight itself starts to move.
Old Feb 26, 2009 | 10:29 AM
redrose's Avatar
redrose
nope...the late c4 module senses motor rotation, cares not what the amperage is...to "bench test" the module you need to hook it to a motor, even an LED used to show module output will only light for an instant before the module shuts down in belief of "motor not running"...do not rely on the module to limit current flow, still need fuses/circuit brkr.
all c4's can significantly reduce load on the headlight drive by hanging the hdlt bezels on your garage wall...few people can see the bezels when the lights are "up" and most vandals ain't quick enuf to do any damage unless the car is parked with lights up(???).
Old Feb 26, 2009 | 02:21 PM
dlb435's Avatar
dlb435
Too bad there is no projection light replacement for the C4.
Old Feb 26, 2009 | 02:27 PM
floridamale's Avatar
floridamale
One thing I do if i'm just running in for a quick stop I leave them up. Just a thought.
Old Feb 26, 2009 | 07:47 PM
Dave Ditner
I've been scouring Ebay for mounting plates for the Targa top and saw gear and pin sets for $14.95. Lots cheaper than a new motor.
To Headlight motor advice???
