Daaaaaaaaaaaaaaaaaaaaaaaaaamn!
Old Feb 28, 2009 | 05:54 PM
  #61
Z51JEFF's Avatar
Z51JEFF
Originally Posted by Epimax
That looks awesome!
What are your measurements from the ground to the top of the fender well, if you don't mind?
I just lowered mine and right now the front is 25.75, and rear is 26.50.
Was thinking of dropping the rear a tad more, but if I don't hit the speedbumps at work just right, I'm draggin the resonator....ugh...!
The front is 25 1/4 and the back is 25 3/4.Those speed pumps can be killer,I wont drive over a speed bump if its too high,if its questionable Ill go around.The front spring is adjustable so I could put the thing on the ground but you have to be reasonable.This cars got 11,000 miles on it,the last thing I want to do is start leaving parts in the road
Old Feb 28, 2009 | 07:36 PM
  #62
MK 82's Avatar
MK 82
Precisely the reason I won't lower mine that low.
Old Feb 28, 2009 | 07:48 PM
  #63
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Old Mar 1, 2009 | 09:57 AM
  #64
Epimax's Avatar
Epimax
Thanks for the info! I might just drop the back another 1/4 , but I'm going to leave the front where it is! That stupid speedbump at work is right inside the gate at the entrance, so there is no way around it! There are 2 of them, side by side, and if go directly between the 2, I'm ok. Just a tad off, and I mean a tad, and scrapppppeee.....
I may go out there with a torch and melt that sucker down to size one weekend!
Old Mar 1, 2009 | 10:12 AM
  #65
takoda's Avatar
takoda
nice ride but it would bottom out on my dirt road
Old Mar 1, 2009 | 10:29 AM
  #66
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Old Mar 1, 2009 | 10:52 AM
  #67
tim32920's Avatar
tim32920
I had a guy come to my house to tint the rear window,we removed the hardware he put soap on the outside of the window,layed his film over it cut it at like 66" acossed the back than trimmed it all around the window we lifted the reat window and tied it to my garage door,he sprayed it down, applied the tint,heat shrunk it,got al the water out,put the struts back on then untied it fom the garage door i held it as he trimmed where the latch goes,reattached new latch,colsed window.Looks perfect and it was the first 92 he had done,he said it was tough but it only took 2 hours so i dont see where it was tough.this guy is great any Floridians want his # let me know ,HE MAKES HOUSE CALLS AND HE ONLY CHARGED ME 75 BUX but that was for 1 window.
Old Mar 1, 2009 | 03:43 PM
  #68
Z51JEFF's Avatar
Z51JEFF
If I get speed bump that has the cut out in the middle Im fine but anything else thats questionable Ill go around it.The only thing on my car the touches anything is the support that runs from the front bumper back to the cross member.I might pull it off and do some work on it down the road.
Old Mar 1, 2009 | 09:56 PM
  #69
Geeorge's Avatar
Geeorge
Watch out for speed bumps
Old Mar 2, 2009 | 09:48 AM
  #70
95wht6spd's Avatar
95wht6spd
They should of cut holes in the tint around the hardware/latch so it would not touch the tint.
Old Mar 2, 2009 | 08:15 PM
  #71
Z51JEFF's Avatar
Z51JEFF
This is a very reputable shop,why they did such a hack job on my car,who knows.
Old Mar 5, 2009 | 02:03 AM
  #72
MaxZR-1's Avatar
MaxZR-1
I just had to post this picture[IMG][/IMG]
That car is sick,any shots of the motor?
Old Mar 5, 2009 | 06:42 PM
  #73
Z51JEFF's Avatar
Z51JEFF
A couple.I took a few when I was replacing the injectors.[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old Mar 8, 2009 | 10:27 AM
  #74
MaxZR-1's Avatar
MaxZR-1
Very nice.I had no idea there was so much under the top of the motor.
Old Mar 9, 2009 | 02:41 AM
  #75
Espresso's Avatar
Espresso
Jeff, to quote multiples.
