Hub Bearing
Old Feb 27, 2009 | 10:37 AM
falconxls's Avatar
falconxls
Default Hub Bearing
I have a suspension from a 1986 I am using in another car. Does anyone know the difference between the hub bearings between an 86 and 93? It looks like the sizes are identical the only difference I see is the ABS sensors are different which I don't need so I was thinking of removing it. Will this work or would I be exposing the back of the bearing when I remove the ABS sensor.
Mike
Old Feb 27, 2009 | 10:49 AM
ejscarfo's Avatar
ejscarfo
The hubs are the same and should fit. I have no idea about the ABS stuff though.
Old Feb 27, 2009 | 11:34 AM
StealthLT4's Avatar
StealthLT4
Sizes are identical, as ejscarfo said, but good point about the ABS sensor. If it opens up the rear, you could always fabricate a plug for the sensor hole.
Old Feb 27, 2009 | 11:46 AM
falconxls's Avatar
falconxls
Default Hub
I thought of cutting the wires flush to the sensor and reinstalling it in the knuckle to plug the hole.
Mike
Old Feb 27, 2009 | 12:36 PM
StealthLT4's Avatar
StealthLT4
Mike
Sounds good to me, as long as you don't mind mauling an ABS sensor. If that's a concern, maybe just cut the wires 2" long so you can re-connect them if necessary.
To Hub Bearing
