Flushing brake fluid
Old Feb 28, 2009 | 12:06 PM
wheelhorse's Avatar
wheelhorse
Default Flushing brake fluid
Has anyone used the gravity method for flushing brake fluid? No pressure or vacuum, no speed bleeders, just open the bleeder and let the fluid run out keeping the master filled until clean fluid runs through then close the bleeders? I needto do my 95.
Old Feb 28, 2009 | 02:19 PM
LTxDave's Avatar
LTxDave
It will take a while to do it that way. Any car I ever gravity bled was a leave it open and come back later type of thing. I'd be worried about letting the MC go dry. I have a pressure bleeder and and it works great. I'd recommend using something like that.
Old Feb 28, 2009 | 02:37 PM
85 500 horse's Avatar
85 500 horse
I use the type that involves an air compressor. I love it. It sucks the fluid out in seconds. I got mine from Griots Garage. The only thing is, you need to have someone stand by the master, ready to fill it immediately because it works so fast.
Old Feb 28, 2009 | 08:42 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
love gravuty method, doesm't take that long and it is racer method
On my 88. with dual MC reservoirs, I break both rear bleeder screws loose first. Have fluid ready to refill MC. I refill about 5 times to get all burnt fluid out/ Close up rear bleeders and move to front
I refill about three times
I like Valvoline SYNTEC brake fluid, it has very high temp tolerance without burming
I used to have to change out fluid two or three time a year, with SYNTEC, it lasts over a year
Old Feb 28, 2009 | 10:14 PM
l98tpi's Avatar
l98tpi
Max G’s
Pressure bleeder and speed bleeders work great. May also be a good time to add stainless steel brake lines as well.
Old Feb 28, 2009 | 10:49 PM
Dads90's Avatar
Dads90
My little Mighty Vac works great as well. Just attach to bleed valve, open and draw fluid thru until clear. Do each one. 30 minute job.
Old Mar 12, 2009 | 04:47 PM
sampaschal's Avatar
sampaschal
I just purchased a set of braided stainless brake lines from Zip and the vacuum brake bleeder from Griot's...have Valvoline Synthetic Brake Fluid on the bench and a complete set of line wrenches. I am waiting for my car to come back from the body shop tomorrow ( cosmetic cleanup of some very minor rash) and the temps to warm up a bit. Mid to high 30s here in Texas with lots of rain. Bummer....we were near 90 degrees last week.. OH well.
Old Mar 13, 2009 | 02:20 AM
65Z01's Avatar
65Z01
After replacing the MC a few years ago I flushed the system with fresh fluid. I placed a plastic tube over the bleeder with the other end in a can of brake fluid and cracked the bleeder.
Then I pumped the brake pedal till fresh fluid came out, repeating at each wheel. Since the "open" end of the tubing was submersed in brake fluid, no air could enter the system when I released the pedal.
Old Mar 13, 2009 | 07:24 AM
Aaron71771's Avatar
Aaron71771
I second the speed bleeders, for $20 you get the set of 4. Makes brake bleeding very trivail.
Old Mar 14, 2009 | 04:55 AM
sampaschal's Avatar
sampaschal
What size are the speed bleeders....anyone know?
Old Mar 14, 2009 | 05:13 AM
WVZR-1's Avatar
WVZR-1
M10 X 1.0 and there are a couple different lengths available for original C4 calipers. If other than OE C4 calipers match the bleeder to the caliper by application.
Every major vendor has "application" charts!
Old Mar 15, 2009 | 09:02 AM
sampaschal's Avatar
sampaschal
"Preciate the response!!....now go find'em..
Sam
Old Mar 15, 2009 | 03:28 PM
CopperCorvette's Avatar
CopperCorvette
Gravity is simple to do just watch your levels and you'll be fine. One wheel at a time.
Old Mar 16, 2009 | 05:29 AM
sampaschal's Avatar
sampaschal
Got'em done yesterday...We used Zip's braided brake lines ( good fit and quality) and replaced all four corners, Griot's suction device to some success...Valvoline Synthetic Brake Fluid Dot 3 & 4. When you are replacing brake hoses, you use a lot more fluid and get some gravity effect from the lines being open during the process. Eventually, I involve the female brake pedal specialist at our house to assist. The pedal is much more firm now. A combination of bled brakes and better hoses.
Old Mar 16, 2009 | 04:36 PM
CAJUN C4's Avatar
CAJUN C4
You need SB1010's
http://www.speedbleeder.com/size.htm
Hope this helps
Old Mar 17, 2009 | 12:49 AM
CopperCorvette
Originally Posted by CAJUN C4
You need SB1010's
Hope this helps
Thanks, I just ordered up a set for the 87 & 94
Old Mar 17, 2009 | 09:00 PM
CopperCorvette
Speed Bleeders called me today to confirm my order. I ordered the 1010 models. They asked if I had upgraded the brakes. I told them that I hadn't. That's when they told me on the early year C4's they take the 1010S. Same price so I asked them to send the correct ones. That's first class customer service. Copper
To Flushing brake fluid
Old Mar 17, 2009 | 10:34 PM
Demonic85's Avatar
Demonic85
In the 3 years i've owned mine i've never bled the brakes
Old Mar 18, 2009 | 11:08 AM
CAJUN C4's Avatar
CAJUN C4
Might double check.I used the 1010's supposedly and they were too short for the fronts of my 95' and brake fluid leaked out because they couldn't seat and the fluid took some clear coat of my front wheels.I had to put back in the OEM's so it wouldn't leak.I believe the rears take the (S's)
Old Mar 18, 2009 | 11:15 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
What makes a speed bleeder better? It looks like the stock bleed screw.
