Where does this connect to?
Old Mar 6, 2009 | 01:45 AM
eviltwin_1987's Avatar
eviltwin_1987
Default Where does this connect to?
Well I was under the dash today still trying to figure out my cruise control issue and I discovered this coming from the wires out of the steering column. Cant believe is was so blind before. Two questions, 1)Where does this connect to and 2)Is it cruise control related(fingers crossed)
The wires are grey, black, blue and pink
Old Mar 6, 2009 | 04:25 AM
floridamale's Avatar
floridamale
Is the car automatic or manual transmission? When I looked in the 87 FSM wiring schematic it did show those colored wires running to the brake switch or clutch switch. So that would be a place to start looking.
Good Luck
Old Mar 6, 2009 | 11:03 AM
eviltwin_1987
96' LT4. 6 Speed. The wires come out of a white colored plastic clip at the bottom of the steering column.
Old Mar 6, 2009 | 04:16 PM
Eakster's Avatar
Eakster
That goes to the Turbo Boost. Is the button no longer operational?
Old Mar 6, 2009 | 04:34 PM
aminnich's Avatar
aminnich
Unless he has two brake pedals it is manual. Sorry, I couldn't help myself. My Bad!
Old Mar 6, 2009 | 05:37 PM
floridamale
Well in the FSM it shows a different switch if its manual that is why I asked I assumed by his name its a 87 which is what I have so I traced the wires. Wasn't sure from photo was early in morning when a answered. Maybe it was to early in AM to do any good what so ever
Old Mar 6, 2009 | 07:29 PM
eviltwin_1987
Sorry, name is the year I was born. Im holding down the fort for the next generation of C4 owners
Old Mar 7, 2009 | 04:46 PM
eviltwin_1987
Any ideas where it plugs into. I am a very tall person and it is difficult to get down under the dash. Any help is much appreciated.
Old Mar 7, 2009 | 05:33 PM
pologreen1's Avatar
pologreen1
Do you know the previous owner? You are best off contacting them to find the history. People get alarms, kill switches, radios, all sorts of stuff, and then keep it or take it out half way. If everything is functioning on the car it is probably extra.
Old Mar 7, 2009 | 10:47 PM
Hot Rod Roy's Avatar
Hot Rod Roy
What's with all the confusing answers, guys? Yes, this is the connector to the cruise control switches on the turn signal stalk. You've got it right! It's mate is just above the hush panel, just behind your clutch pedal (or the left brake pedal).
Old Mar 8, 2009 | 02:57 PM
eviltwin_1987
THANK YOU Now to get myself under that dash. Is the "mate" going to be a connector that is mounted, shared with other wires....? thanks.
Old Mar 9, 2009 | 08:04 PM
eviltwin_1987
Any idea what the connector looks like? I am going to try and find it after work today.
Old Mar 10, 2009 | 08:38 PM
eviltwin_1987
If this is the connector you are talking about, it definentally wont work when compared to the connector on the wires. Please help me locate where this wire goes.
Old Mar 11, 2009 | 03:21 PM
eviltwin_1987
Bump
Old Mar 13, 2009 | 07:07 PM
eviltwin_1987
bump,,,, help
To Where does this connect to?
