While trying to remove the air condition compressor, as suggested by
a few forum members, to access my driver side wires, I rounded of
one of the long narrow bolt heads just underneath the compressor. I don't know if that particular bolt is like "frozen" on or what. Anyone
suggestions as to its removal would be greatly appreciated. Incidentally, I first tried accessing from underneath—couldn't get a good enough grip on the boot. I don't know how some of you do it this way. I am still wondering if after the compressor is removed if I will be able to access the wires. HELP!
THANKS
If you haven't rounded it too bad, get a 6 point socket or box end wrench and try it one more time. Sometimes an open end wrench or a 12 point socket/wrench will start to round the head of the bolt and the 6 point can save it. Good Luck
If the corners are really rounded too much for a six point socket, I've had good luck with sockets and wrenches that grip on the flat of the bolt or nut. I tried to find a picture to post, but had no luck. Maybe someone else can come up with a picture. Good luck.
They are very useful in these types of situations. You can also buy a set of 'stripped bolt removers' that do the same thing, but have more of a blade on them, so they dig in more.
Sears sells the side-gripping ones, though it's a 'special' item and is just in a random place in the store. Found them by accident while browsing the tool section last week.
