Asr?
Old Mar 9, 2009 | 06:26 PM
bangand0lufsen's Avatar
bangand0lufsen
Default Asr?
Ok so my asr on and or off lights do not come on. Any ideas on how to fix this. MY guess is bulbs or fuse if a fuse what fuse would i check. Any other suggestion greatly appreciated.
Old Mar 9, 2009 | 07:02 PM
StealthLT4's Avatar
StealthLT4
Well I would check first to see if its an indicator problem or the ASR actually isn't turning on/off. Only one way to do that . Then troubleshoot from there, knowing whether it's the unit itself or the indicator.
Old Mar 9, 2009 | 07:33 PM
bangand0lufsen
inless iv lost allot of power it would seem its always on when ever i start my car then if i press it once it loses some traction sadly i cant try to test that theory to much to do some things going on tear. but it appears to be working. But brings me to another thing i got on it the other day and my break light came on service asr and abs lights all came on but everything is working fine no issues at all its only happend a couple of times didnt think much of it since i pulled over tested to make sure it seemed like it was working turned it off then back on was again running just fine??? any ideas maybe i have more then one problem. PS the asr light as never worked since i have owned the car!!!
Old Mar 9, 2009 | 11:51 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
It is programmed to reset to "on" every time the car is turned off. If you lose traction when you press it once then it's working and the problem is the light.
If you really want to test it go to a quite street or parking lot and turn off the car. Then restart, bring the revs up to about 2500 and pop the clutch. Now, without turning the car off press the button once and repeat. If the view in your rear view mirror now looks like LA on an August day your ASR is working.
To Asr?
