Antenna
Old Mar 10, 2009 | 06:44 AM
tim32920's Avatar
tim32920
Default Antenna
I was reading a post about adding a toggle to power the antenna,I have an xm receiver and if im not listening to it I listen to cd's so...
Does anyone know how to wire one up?
Old Mar 12, 2009 | 01:39 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Does your XM receiver use the regular antenna? Does the antenna go up and down automatically when you turn the receiver on and off (with ignition on)? If so, you can use the same technique, since the antenna doesn't care what kind of receiver you have.
Put a switch in the orange wire to the antenna relay, which is located under the rear "halo" around the hatch, on the left side. With the switch off, the antenna will stay put. With the switch on, it will be automatic.
If you want the antenna down, turn off the receiver, wait for the antenna to go down, turn off the switch, then turn the receiver back on.
