Any recommendations for an electric impact wrench? I don't have any experience using impact wrenches and don't have an air compressor. Are they available with adjustable torque settings?
I use one they work well but as most things the more you spend the better the tool. Can't remember the cost the one I have is older have had it a long time
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I've got a sears pro series I had for over 15 years, it was about $250 back then and has had alot of used but looks and performs brand new. Very happy with mine. It true, you get what you pay for.
I got the DeWalt 18v cordless impact wrench for X-mas, and I LOVE it! It can do up to 300 ft-lb, which is more than I'll ever need, and works really well. They had it for sale for $200 when I got it, and you can probably find that price online somewhere. Here's the Sears link: http://www.sears.com/shc/s/p_10153_1...+impact+wrench
I have one for sale. Actually I never thought about selling it, but then I just don't need it anymore. About $100 shipped. Send me a PM if you are interested.
I checked out the link and it looks good. Sorry for my ignorance, but can the torque be adjusted? Seems I've heard of people over torquing bolts with disastrous results.
Kim,
I have an Ingersol Rand that I really like. It was around a 100.00 or so. It's fairly light which is always a plus. Usually the cheaper ones are kind of heavy and gobble up air.
You don't actually use a torque wrench to torque bolts to spec, you mainly use it to get bolts off. Then, when putting bolts back on, it's pretty easy to regulate the torque. I mainly use mine for wheel lug nuts, and when I put the nuts back on, I'll tighten them snug with the impact wrench and let it "impact" on them for about 1 second once they are seated. This gets them relatively tight, but well under the 100 ft-lbs that the nuts are torqued to. Then I go around with my torque wrench and torque them all down to spec.
Kim,
Get a good one, don't cheap out on one.
Actually the electric ones are pretty easy on air Mike.
Battery ones rock !! I have a corded one I use on the farm and it is really usefull but I had a cordless for a while at home and it was great. I have air at home but its nice to not have an air hose to drag around.
I use my Harbor Freight cheapie to remove the lugnuts and to snug them back on. Then the torque wrench finishes the job. Lazy mans ratchet, but it works for me.
I think I'm getting the picture now. An impact wrench is used mostly to remove bolts/nuts. They do not have adjustable torque settings, and they can be used to install nuts but finessed in such a way as to not over tighten bolts/nuts.
Someone said that an impact wrench would be useful to tighten the spring retainer bracket nuts (front leaf spring retainer brackets) without allowing the bolts to spin. How could this safely be done with an impact wrench that has 300 lb./ft. (ft./lbs. ?) of torque, and nuts that need to be torqued to only 48 lb.ft.? Also I don't quite understand how you can tighten lug nuts without over torquing them. I'd hate to spend good money on a tool that in my inexperienced hands could be a lethal weapon.
Thanks for your patience folks.
Kim
yes mine has 4 different settings, 1-4 then they give you lbs per setting. I never had an electric, but my grandfather had a junk one. I love air tools, everything I have electric I have in air also.
You just let go of the trigger. If you just hold the trigger and let it hammer, bolts will get very tight or snap off. They really come in handy for removing stuff that has been bolted together for 100 years or is rusted up.
It doesn't immediately torque the bolt/nut to 300 ft-lb. It only gets that tight if you let it sit and hammer on the nut for several seconds. I would estimate that, letting it hammer for about a second, it gets to roughly 40 ft-lb. If you let go of the trigger as soon as it starts hammering, then it will only be snug. It sounds complicated, but it's really easy once you actually get it in your hands and see what we're talking about
I've been wanting to get one myself, but just wasn't sure which would be best for me (Air vs Elec). After reading the posts, I think an electric would suit my purposes just fine. I really like that DeWalt that was referenced!
Similar, I got a no name ebay auction for $85 24 volt with two batterys and it works great. My grandson and I autocross so it gets a workout the past two seasons. With it and a reasonably priced torque wrench we have made out like a bandit, it has paid for itself several times.
My harbor feight did not do the job. Northern Tool has a 24volt that will spin just about any lug nut off. It's about 125, a great tool. 2 batteries and a plastic case.
