rear view mirror
Old Mar 11, 2009 | 07:52 PM
BEEMRZ's Avatar
BEEMRZ
Cruising
Default rear view mirror
Hi Folks FNG Lurker here. It seems that my rear view mirror has lost the friction reqd. to keep it at adjustment while driving. Any suggestions?? Thx
Old Mar 12, 2009 | 09:09 AM
Vette Gator's Avatar
Vette Gator
I was able to fix mine by making tool in our machine shop. I turned two disks with curved interior surfaces that matched the curvature of the barrel that is crimped over the ***** at each end. Each disk was cut in half and the two disk halves were connected with threaded rods to set the distance between them. The diameters of the disks were a bit smaller than the barrel ends. The tool was assembled around the barrel, then I used an arbor press to squeeze the barrel ends. I rotated the barrel 90 degrees, then squeezed again.
This method worked pretty well, although I had to touch up the black paint at the ends of the barrel where it was scratched by my die. The only other alternative I've seen is to buy a new one.
Old Mar 12, 2009 | 12:24 PM
Gary96's Avatar
Gary96
I had to adjust my mirror after every bump that I hit. It wound up being the screw that attached the mirror bracket to the car was loose. You might check that first.
Old Mar 12, 2009 | 12:50 PM
mrmtrtrnd's Avatar
mrmtrtrnd
If you can't tighten your mirror and need to replace it look in the for sale section, for someone parting out their car and pick up a used one. Good luck and I hope it's a easy fix. Ray glad to have you on the forum.
Old Mar 12, 2009 | 12:59 PM
Aardwolf's Avatar
Aardwolf
There was a thread on here about putting a screw into the housing and using that for tension. For a quick fix I put some glue on mine. :o
Old Mar 12, 2009 | 01:51 PM
davidarnesen's Avatar
davidarnesen
on my 85 i said F*** it and took the stock one off, and then got a cheap one from autozone and glued it to the windshield, noone ever noticed, cost me 15 dollars and could see out the back just fine
Old Mar 13, 2009 | 01:42 AM
Wayne88's Avatar
Wayne88
The ball was loose on my rear view mirror. I tried glue, and finally bought a new mirror. About $100.
Old Mar 13, 2009 | 06:22 AM
Sheri'sCherry87's Avatar
Sheri'sCherry87
0riginally Posted by davidarnesen
see out the back?? i thought that was 4 putting on makeup!
Old Mar 13, 2009 | 04:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
If it is a problem w/screw coming loose, do as I did and use loctite on the screw.
Old Mar 16, 2009 | 10:00 PM
BEEMRZ's Avatar
BEEMRZ
Cruising
Thx for the replies folks. It is definitely not enough friction on the *****.
I like the super glue idea. Thx again .Makeup!!!!!!!!!!!!!!!!!
To rear view mirror
