Swapped my seats
Old Jan 27, 2002 | 05:26 PM
robblk90's Avatar
robblk90
Default Swapped my seats
It was nice outside this weekend so i decided to swap my seat cushions. After 50k miles the driver seat was showing a little wear on the outside bolster. These are the standard seats. The cushions took about 5 minutes to remove all four pieces and swap them. While the cushions were out I removed the frames (4 bolts) and cleaned under the seats. I found about $3 worth of change under the driver's seat and it isn't my daily driver. Had I known it was this easy I would have done this along time ago. Nice little free project.
Old Jan 27, 2002 | 07:16 PM
91Vette's Avatar
91Vette
Default Re: Swapped my seats (robblk90)
I hear that the seat cushions just snap into the frame. Is this true? How hard were they to get out?
One of these days I am going to buy the covers installed over the foam. Just curious if I am getting in over my head.
Old Jan 27, 2002 | 07:32 PM
SLICKMAN's Avatar
SLICKMAN
Default Re: Swapped my seats (91Vette)
I did this on my 91 with Sport Electric seats too... Its a snap!!! Thay just snap in and out :cool: :cheers: :cheers:
Old Jan 27, 2002 | 08:28 PM
robblk90's Avatar
robblk90
91 Vette, It's very easy. They just snap in. One on the bottom and 4 on the backs. I plan on getting new covers also. Even thought about the Wet Okoles too.
Old Jan 27, 2002 | 11:36 PM
91Vette's Avatar
91Vette
Thanks for the info!!
Old Jan 28, 2002 | 05:43 AM
GlockLT4's Avatar
GlockLT4
I think I'm going to pull my seats out this week while I'm waiting on Andrew at akmcables.com to fix my PCM for me.
Old Jan 29, 2002 | 02:01 AM
Jsailor24's Avatar
Jsailor24
Default Re: Swapped my seats (Glock'94)
Hey! no school wednsday-- just found somthing to do- Ive looked before and it seems like the cussion (cover & foam) wont come off the frame without breaking somthing. do you have pics of tthese tabs or can you explain this to me a little better?
Old Jan 29, 2002 | 02:57 PM
robblk90's Avatar
robblk90
Default Re: Swapped my seats (Jsailor24)
Hey Jsailor24 I can do one better. We live in the same town. I can show you in person. I am off work Wednesday and would be glad to show you. As long as the weather holds out. Let me know if you want. It takes about 5 minutes to do. I think we have spoken before. You can IM me on AOL-----FD2BLAK is my screen name.
[Modified by robblk90, 1:00 PM 1/29/2002]
Old Jan 29, 2002 | 02:59 PM
C4Cvette's Avatar
C4Cvette
Can the seats be swapped in a 94? I know that the bottoms come out very easy, but what about the backs? Anyone?
Old Jan 29, 2002 | 03:06 PM
robblk90's Avatar
robblk90
Default Re: Swapped my seats (C4Cvette)
Not sure about sport seats but the standard seats are very easy. There is a metal handle at the front of the base of the seat. Push down on the cushion and pull down on the handle and then push it towards the back of the seat. The lower cushion just lifts out. For the backs, push in toward the center on the outside edge of the cushion about half way down the side. As you push in pull out toward the steering wheel to make sure it is unclipped.There is a clip on the opposite side as well. There are two clips in the headrest also. Follow the same procedure. Don't be afraid of hurting the cushion you might have to use some force to push in on the headrest. Once you get the first clip it is very easy.
Old Jan 29, 2002 | 03:50 PM
KORE YOME's Avatar
KORE YOME
Glock....you didn't accidentally trip over the cord while you were programming did you? :nono: What happened to the computer? You are using the LT1_edit software, right?
To Swapped my seats
