Help
Old Mar 14, 2009 | 08:44 PM
Bulldog Steve's Avatar
Bulldog Steve
Default Help
Hello,
i was working on my car and the plastic connector for the o2 sensor just broke into little bits. Can i get a new one and splice it in and where would i find such a thing!
What brand of O2 sensor should i get. should i go to the steakership and get on there.
Thanks for all your help
Steve
Old Mar 14, 2009 | 09:23 PM
Race Prepared's Avatar
Race Prepared
Yes, you can splice a new connector to the existing wiring. You should be able to locate a new connector at the local auto supply. Good luck!
Old Mar 15, 2009 | 08:54 AM
Bulldog Steve
Thanks i will go by napa and see if they have one.
Steve
Old Mar 15, 2009 | 09:22 AM
Muffin's Avatar
Muffin
Most folks have good luck with Bosch O2 sensors.
Old Mar 15, 2009 | 11:01 AM
Bulldog Steve
Old Mar 15, 2009 | 11:38 AM
pianoguy's Avatar
pianoguy
I just installed a couple of Denso's, but haven't had them on long enough to discover whether or not they're good. Price was right, though.
Old Mar 15, 2009 | 01:43 PM
CopperCorvette's Avatar
CopperCorvette
If your going to splice a new connector onto the wires I suggest you also get three small pieces of "Heat Shrink" tubing. Two smaller ones for each wire and use the larger dia. tube to slide over both wire and give it a much cleaner look.
Old Mar 15, 2009 | 04:01 PM
Bulldog Steve
Copper,
So you are saying i can get a male and female instead of buying a new O2 sensor.
Steve
Old Mar 15, 2009 | 04:37 PM
pianoguy's Avatar
pianoguy
Here's a source for connectors:
http://eficonnection.com/eficonnecti..._pigtails.aspx
Old Mar 15, 2009 | 06:26 PM
Bulldog Steve
Thanks for the link.
Steve
To Help
