need help with shorting problem
Old Jan 27, 2002 | 10:18 PM
oneqwk's Avatar
oneqwk
Default need help with shorting problem
have short, when i hit brake pedal, hazzard and brake light fuse blows. i have tail lights and turn signals, they are not affected. checked wiring i could get to. turn signal used same bulbs that show brake it think so should not be there. sometimes i put a fuse in it and it is ok for a few hour. but get is car and hit brake pedal, fuse blows and no brake lights or flashers. would relay or flasher cause this problem, need help, driving me crazy. thank you, jerry
Old Jan 27, 2002 | 10:24 PM
bogus's Avatar
bogus
Default Re: need help with shorting problem (oneqwk)
sounds like something has given up at the pedal...
if you want, I am in Wyoming... we could look at it on Saturday?
