I'm trying to determine how many fuel pumps are on later (93-96) C-4s.I know the ZR-1 had two but did any other ones....?And if so what was the purpose.....Thanks in advance for any help......
Yea the ZR-1 has two pumps because it has 16 injectors. One pump supplies the primary injectors, #1 pump. The secondary injectors are supplied by #2 pump when they get called on line. The system was done that way to get past the CAFE and EPA regs, I think.
We have a key on the center bezel (where the radio is) that enables the system. It's called the "valet key"...you turn it off & take it with you if you leave your Z to the parking lot attendants...like that's ever gonna happen.
