Wheel Bearings
Old Mar 16, 2009 | 04:25 PM
Bulldog Steve's Avatar
Bulldog Steve
Default Wheel Bearings
So what kind of symtoms can i expect if my rear bearings are going out.
What my car is doing is after i come to a stop it sounds like a coke bottle is rolling up and hitting the back if the rear trunk if it had a trunk.
A clunk now this is after a complete stop! I have replace the u-jts. about 1 yr ago.
Steve
Old Mar 16, 2009 | 04:50 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Could be the bearing, could just be rust on the splines.
Jack it up and see if anythings loose.
Old Mar 16, 2009 | 04:54 PM
CAJUN C4's Avatar
CAJUN C4
Check for radial runout of the bearings.Take wheel(s) off attach a dial indicator on the flange at the castle nut.When you pull the rotor side to side it shouldn't have more than 0.005" on the indicator.If more,change the bearings.
To Wheel Bearings
