oil pressure
Mar 16, 2009 | 06:48 PM
oil pressure
10-15 psi ok at idle? sounds like it might be a little low but? what cause low oil pressure? bad pump? the motor doesnt knock at all, its an lt4
Mar 16, 2009 | 07:36 PM
I wouldn't sweat that at hot idle.
I have seen older motors(like mine) that are loose and that is about right for hot idle. Let's wait for some LT4 gurus to chime in to be safe but as i wrote it wouldn't alarm me.
Mar 16, 2009 | 08:08 PM
From: The reason time exists is so everything doesn't happen at once
Doesn't appear to be too low. Does the pressure increase as soon as the revs increase?
Mar 16, 2009 | 08:11 PM
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I notice my LT4 doing that, it gets up to 40+ once I rev it. I can't wait to put this animal on the road
Mar 16, 2009 | 10:06 PM
Thats about what my L98 has at hot idle an I haven't had any problems...WW
Mar 17, 2009 | 02:53 PM
Ten sounds a little low to me. On an LT1 you want to see a floor of about 15-20 at hot idle.
Mar 17, 2009 | 03:21 PM
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I've never seen my stock '88 (131k) L98 pressure below 22 on the hottest of summer days.
Mar 17, 2009 | 08:51 PM
Quote:
Originally Posted by
Camaro350z28
How many miles?
On higher mileage engines indicative of increased clearances on the crank journals bleeding off pressure.
Mar 17, 2009 | 08:59 PM
Mar 17, 2009 | 09:28 PM
Old time rule of thumb: 10 PSI for each 1000 RPM.
Mar 18, 2009 | 04:09 PM
Muffin
If I was only getting 20psi at 65 mph I would be worried as he**
Mar 18, 2009 | 05:52 PM
markKlein
Why?
