Battery drain
Old Mar 22, 2009 | 08:00 PM
jmassey139's Avatar
jmassey139
2nd Gear
Default Battery drain
Thank you for letting me in your forum,
my problem i,m having with my 1991 corvette is interior lights will come on and horn will honk until battery os dead if your not around.half of the digital dash is dim and upper part is bright sometimes.have heard there is little switches inside the doors possibly acting up or the ccm.has anyone ever ran into this condition.thank you jerry
Old Mar 22, 2009 | 08:09 PM
Jim Nichols's Avatar
Jim Nichols
Couple of questions. How old is the car? Do you run every few days? C4's are notorious for draining batteries. I have been thru 4 in the last six years. Put up a little more info.
Old Mar 23, 2009 | 12:27 PM
jfb's Avatar
jfb
Yes door switches can go bad keeping the courtesy lights on and activating the theft alarm. GM says leakage current should not exceed 50 milliamps. Also, car batteries should not be left sitting doing nothing for long periods (4+ wks) because all lead acid batteries self discharge up to 1% each day even disconnected and if not charged up periodically their plates get coated with lead sulfate which is a good insulator and your battery then is a door stop. Buy a battery tender and keep your battery charged. Battery tenders measure the battery voltage and when the battery loses 10% of its capacity, the tender charges it up and then shuts off.
To Battery drain
