I have an early production 1995 LT-1 Coupe. The vin is under 235. Does anyone know where I could review records to determine if this is a first or second day production corvette. The corvette was built on August 4, 1994. The sequence number on the build sheet is 139. The number 39 is on my spare tire by a grease pencil and the number 39 is also written by grease pencil under the air cleaner filter.
Thanks in advance
Post the VIN and I believe I can take the count down by just modifying the VIN and randomly check for build dates. Ironically some production days are included with a VIN search but others are not! There's also build and order dates. I believe there may be discrepancies. A build sheet is I believe generated from the "order" and the "production date" is actually determined by the physical build.
I can "poke at it" randomly but with a "correct vin" it makes life a little easier! I can't accomplish this today but I could be back with the information "if there is" Monday!!
