shift kit
Old Mar 28, 2009 | 08:21 PM
ragged claws's Avatar
ragged claws
Default shift kit
I've seen people here speak highly of shift kits for an auto transmission. What is a shift kit and what does it do?
Thanks, Kim
Old Mar 28, 2009 | 08:28 PM
Relic's Avatar
Relic
Funny, I was just reading on this and high stall converters. Never did understand the auto trans, and I don't think I ever will.
I think I figured out I don't need a high stall coverter. Seems from what I read, it won't help an L98 that much, and would be more of a benefit to racers.
A shift kit, from what little I was able to figure out, firms up the shifts, depending on the kit. Something about enlarging the holes for fluid flow, makes it feel more like a manual.
I'll be watching this thread for when someone who knows what their talking about replies!
Old Mar 28, 2009 | 08:48 PM
Aardwolf's Avatar
Aardwolf
I installed one in my '88 and have been very pleased with it. I think I paid around $30 shipped. I hadn't installed one before and was a little unsure how it would go, but it really wasn't hard at all. The worst was jacking the ungodly heavy valve body into the trans while making sure the check ***** didn't fall out or the gasket slip.
It makes the shifts much faster, and can make them much more crisp depending on what you set it for. To hard can be uncomfortable in a low RPM shift, head jerking. The more expensive kits like the Transgo take care of that though from what I've read. I've also read that kit install is more then just changing out a few parts in the valve body.
Old Mar 28, 2009 | 09:56 PM
qws's Avatar
qws
I have the B&M shift kit. When I put that in with a 2000 stall and orginal gears 3:07 at low rpm, such as leaving a stop light it would really bang into the next gear. If you were to leave full throttle you really didn't notice it.
Now I've got one of Petek's TQ with d44, 3:45's and with just normal driving you don't notice it banging into the next gear as hard.
Old Mar 28, 2009 | 10:26 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Mar 29, 2009 | 12:16 AM
Muffin's Avatar
Muffin
I put a B&M in mine along with a B&M Master kit.Master kit simply beefs up the trans. As has been said a shift kit firms shifts. My 1 to 2 is harsh, 2 to3 is crisp 3 to 4 is almost unchanged. Driving in traffic the hard shifting becomes a major pain to my way of thinking. IF you are into hard launches it is the way to go. I don't race any longer and wish Ihad my old shift pattern back.
Old Mar 29, 2009 | 01:03 AM
Calderone's Avatar
Calderone
i have the B&M 2400 Holeshot converter and B&M Shift kit
Not a dramatical change,but i tried it and i like it,im not sure about the converter
but i guess its better.- My goal i guess is to delete everything that is stock
Old Mar 29, 2009 | 03:00 AM
Weav's Vet's Avatar
Weav's Vet
I have a performance tune on my '96 which includes firming up the shifts. I wanted it to be firmer so rather than sending my PCM off again I decided I'd try one of these. It's a nice little toy to play with. There is definitely a change in the firmness of the shifts. The firmer of the two settings is down right hard.
Old Mar 29, 2009 | 05:16 AM
toptechx6's Avatar
toptechx6
But will not work on raggedclaws 89 since it is hydraulically controlled, not electronic.
Old Mar 29, 2009 | 05:57 AM
Weav's Vet's Avatar
Weav's Vet
You are absolutely right. Just thought it may be of interest.
Old Mar 29, 2009 | 09:53 AM
ragged claws
Thanks for all the info, guys. Since a shift kit won't work on my car I have to figure out another way to spend money on my car. Not to worry, I'm sure something will turn up.
Old Mar 29, 2009 | 10:03 AM
Pete K's Avatar
Pete K
Who said a shift kit will not work for your car?
Shift kits alter line pressures, and manipulate the accumulators (shock absorbers) involving each shift.
If you like the results a shift kit provides, they are cheap, somewhat easy to install, and enjoyable.
I would recommend avoiding the transgo kits for a few reasons:
On certain model years (specifically 1993) they flat out dont fit.
They are expensive.
They are very complex to install
They lock the 3rd gear accumulator (band apply pin), and I am starting to see transgo units burning the band. Normally, burnt bands are not common.
B&M kits lock the 1-2 and 3-4 accumulators, and have an (internet) reputation of breaking planetaries. In my experience, I have never seen any transmission that were negatively affected by the B&M.
Old Mar 29, 2009 | 10:16 AM
Weav's Vet's Avatar
Weav's Vet
I think this is probably my fault for throwing the Shift Switch post in there. My bad and apologies to the OP.
Old Mar 29, 2009 | 10:21 AM
Pete K's Avatar
Pete K
Shift kits help to get back some of the shift firmness that is normally lost after installing a higher stall torque converter.
On the same token, some nitrous guys intentionally do not install shift kits because they would rather have the "slushyness" of the torque converter save driveline parts.
To shift kit
