ZF shifter question
Old Mar 31, 2009 | 07:44 AM
njdubya's Avatar
njdubya
6th Gear
Default ZF shifter question
I am building a custom '59 Jagaur Roadster (from a sedan) and using a 6speed ZF transmission I purchased on ebay. It is mounted and appears to be in very good condition. My questions is, what do I need to make the reverse lockout functional? Or can I eliminate the lockout without likely damage? The shifter came with the stick and I notice an internal piect inside. I have found a couple of shift ***** on ebay with the button, but do I need anything additionally? Any help is appreciated!
Old Mar 31, 2009 | 08:16 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The small cylinder that runs down the middle activates the reverse lockout. There should be a ring that slides over the outer shaft and a set screw to hold it to the inner small shaft. If you do not have these then you can disassemble the shifter and remove the lockout with no ill effects.
Old Apr 1, 2009 | 08:41 AM
njdubya's Avatar
njdubya
6th Gear
Thank you! Nick
To ZF shifter question
