Electronic Control Module Help
Old Apr 1, 2009 | 09:58 AM
Princ4ever's Avatar
Princ4ever
Cruising
Default Electronic Control Module Help
I am trying to hunt down an ECM for my '93 Ruby. Can I only use one from a '93? Are there specific numbers on the ECM that I am looking for that will tell me that it will work with my car? This is in case I buy on Ebay. Lastly, is there anyone left that rebuilds them? Thank you in advance for your help.
Thanks,
Shawn
Old Apr 1, 2009 | 01:50 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
here is a link that should help you if you want to try and rebuild it yourself.
http://www.batee.com/corvette/acrepa...oard/c68.shtml
Old Apr 1, 2009 | 08:18 PM
rodj's Avatar
rodj
92-93 Vette only
If buying 2nd hand confirm service # as earlier model 1227727 used on 90-91 TPI is identical appearance
This place has been mentioned on here before for rebuilds
http://www.siaelec.com/index.asp
http://www.siaelec.com/index.asp?Pag...D&ProdID=38815
Also
http://www.autoecmecu.com/chevrolet-ecu-ecm.html
Old Apr 1, 2009 | 09:01 PM
jabez's Avatar
jabez
Good luck. 92/93 ECMs are hard to find. If you do find one it will be pricey. Your best option is a re built one.
Old Apr 2, 2009 | 02:46 AM
rodj's Avatar
rodj
Rebuilt one with warranty on eSlay for $200 BIN
To Electronic Control Module Help
