MSD Ignition Control Question
Old Apr 8, 2009 | 04:12 PM
VetteFreak91's Avatar
VetteFreak91
Default MSD Ignition Control Question
I was just wondering how many horsepower the MSD actually gives the corvette. It seems like a cheap way to get a little extra hp. Thanks guys.
Old Apr 8, 2009 | 06:35 PM
BAM92's Avatar
BAM92
I would think none on a stock engine.
Old Apr 8, 2009 | 06:49 PM
Klondike's Avatar
Klondike
On mine, about 330HP LESS above 5000rpm! Replace, replace, Warranty replace.....you can spend the rest of your life sending their junk back to them, only to get another one that will go bad six months later. I've had their stuff on 3 different (brand) cars and all of them developed problems that went away when I went back to stock ignition. I'll never buy any of their junk again. For me MSD= Made a Stupid Decision
Old Apr 9, 2009 | 10:45 PM
VetteFreak91
Thankyou Klondike I needed to know the bad and the good. Allot of people swear by it and only a few people say that it fails.
Old Apr 10, 2009 | 09:51 AM
Aardwolf's Avatar
Aardwolf
Don't waste you money. You could do a real mod like 1.6 rockers or something for the same cost.
Old Apr 10, 2009 | 02:55 PM
Calderone's Avatar
Calderone
ive heard Accel is better ?
Old Apr 10, 2009 | 03:19 PM
jfb's Avatar
jfb
Is there something wrong with your brain that you don't understand how the spark ignites the fuel air mixture in a cylinder? A higher energy spark has insignificant increase in odds of igniting the mixture. If the odds were so bad, don't you think GM would have increased the spark energy? The only increase in HP you could possibly get is from the slightly better increase in odds of the spark igniting a cylinder and you not losing that one power stroke. I would bet you wouldn't see any difference in HP between two runs of the OEM and the MSD spark system.
All the aftermarket go faster stuff advertise increased HP so they can drive Ferrari's instead of Cavalier's. Apparently THAT part works, I doubt the HP increase works.
Old Apr 10, 2009 | 03:42 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
If your going with boost or nitrous then upgrading the ignition is worth it.
I've seen racing ignition have fits when driven daily, especially the 1st time it rains
Old Apr 10, 2009 | 07:45 PM
larry00's Avatar
larry00
I have a couple MSD multi spark W/ Rev Limiters. Run one on the LT 4 hot rod.
The old one has been around and on several vehicles and still works well.
On the other hand my Accel Distributor went south after about 500 miles.
On a stock or lightly Modded eng. multi spark is not necessary and at RPM's below 7500 the stock OPTI is as good as the aftermarket.
Only when you get to full race high HP engines is more hotter spark necessary.
The OEM factory OPTI is equal to or better than aftermarket , 160,000 miles and often go 250,000 .
It's not the OPTI's fault it was put in a bad position on the engine.
BUY OEM or quality ICM [ Ign control modules ] too not discount suppliers.
Bryan I was reading up on my ACCEL GEN 7 computer and it recommended quality wire not the cheap Chinese crap I usually buy.
I went to Radio Shack and bought quality butte connectors made of silver and used them on cheap a$$ed wire. Oh Well !
Redoing wiring again and getting coil wire away from ICM and MSD 6 A and IAC stuff.
Going to get it right one of these days.
To MSD Ignition Control Question
