Any suggestions
Old Apr 14, 2009 | 09:32 PM
MoFun's Avatar
MoFun
Default Any suggestions
My father has a 92'. He put a set of trick flow heads, an upgraded cam, plugs, wires, distributor. It ran great for about three days. Now when it starts it'll run great for about 5 minutes. Then it starts backfiring, an missing, an the check engine light comes on. Its giving out a code 36. We changed the plugs an wires(4 of the wires were melted on the exhaust headers) but problem still exist.
Old Apr 15, 2009 | 04:14 AM
Weav's Vet's Avatar
Weav's Vet
Check the connection on the MAF sensor. Also check your burn off relays.
Old Apr 15, 2009 | 05:29 AM
toptechx6's Avatar
toptechx6
No MAF on a 92, it is speed density. Code 36 on a 92 is related to the Opti, I would trouble shoot the circuit using the FSM. You may have gotten a bad one.
Old Apr 15, 2009 | 09:12 AM
89 Jaws's Avatar
89 Jaws
I have seen something like this before. Make sure no other wires or bundles are even close to the headers in front or behind
I had this happen with my first vette after I changed the heads and again on our boat when the zip tie broke and the ignition bundle fell on the exhaust manifold.
Good luck
Old Apr 15, 2009 | 09:32 AM
TWISTERUP's Avatar
TWISTERUP
Also check connector/terminals and harness to opti. Some brands of optis seem to have less trouble then others IMO
To Any suggestions
