Failed Emissions
Old Feb 1, 2002 | 10:43 AM
rjs82vette's Avatar
rjs82vette
Default Failed Emissions
I know this is for C4's but maybe you all have some ideas.. My ride failed emissions. the results were...
HC ppm 278 @ 15 MPH 242 @ 25 MPH----FAILED
CO% 2.41 @ 15 MPH 2.31 @ 25 MPH-----FAILED
NO ppm 281 @ 15 Mph 319 @ 25 MPH----PASSED
I dont have a lot of time for trouble shooting and would like information on the most likely problem... Just so I have a good place to start when I get the time...
1982 350 Crossfire, 100% stock, all original emission equipment
Thanks for all the help....
RJ
Old Feb 1, 2002 | 12:37 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Failed Emissions (rjs82vette)
Don't know about the crossfire, but you are running way rich! Make sure O2 sensor is working and the ECM is going into closed loop. Make sure air cleaner not completely clogged up. Make sure fuel pressure is not way too high.
Hope some crossfire folks can get in here!
Old Feb 1, 2002 | 12:44 PM
JonM's Avatar
JonM
You may want to change that fuel filter also. Check that the EGR Valve is working properly. When was the last time you tuned it up and changed the wires, cap, rotor, and coil? Unplug the two injectors and crank the car over, you should see no fuel being delivered. If you do you have leaky injectors that need attention.
Old Feb 5, 2002 | 10:58 AM
rjs82vette's Avatar
rjs82vette
Default Re: Failed Emissions (JonM)
I found out what was wrong.... The AIR Diverter Valves are bad, and all three Check Valves were bad... The Check valves I can find but the Diverter valves have not been made since 92....
Thanks for all your help...
To Failed Emissions
