Really strange argument
Old Apr 19, 2009 | 06:25 PM
planet's Avatar
planet
Default Really strange argument
Did the 1988 35 th. aniversary model come out with regular motor oil or did it come with synthetic motor oil? I sal that synthetic was not widely used at that time.
Old Apr 19, 2009 | 06:28 PM
pologreen1's Avatar
pologreen1
Old Apr 19, 2009 | 06:32 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Apr 19, 2009 | 07:40 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I have an 35th Anni with a Mobile 1 sticker above the radiator (96k miles). I don't think is is original but the previous owners put it there for some reason. I use Mobile1 5-30 and it does not leak or burn so it works for me.
The owners manual does not specify Mobil1
Last edited by pkazsr; Apr 19, 2009 at 07:46 PM. Reason: Research in owners manual
Old Apr 19, 2009 | 07:44 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I believe the use of Mobil 1 as the factory fill started in 92 when the LT1 came out. The optional oil cooler was dropped that same year.
Kmcoldcars's Avatar
Kmcoldcars
My 1991 owners manual says to use regular motor oil, not synthetic. The 1992 and up LT1 engine uses synthetic. The earlier L98 engines did not generate enough heat to require synthetic, from what I have read.
Old Apr 19, 2009 | 08:06 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Per the info in the Corvette Black Book, you are correct. The only exception were the B2K Callaway Twin Turbo optioned cars. They used Mobil 1.
Old Apr 20, 2009 | 09:07 AM
Goldcylon's Avatar
Goldcylon
So did the ZR-1s
Old Apr 20, 2009 | 09:42 PM
RedVette84's Avatar
RedVette84
Can't hurt to be a little extra safe.
Old Apr 20, 2009 | 11:27 PM
Sweet 90's Avatar
Sweet 90
Originally Posted by Goldcylon
So did the ZR-1s
The 1990 ZR-1 according to my owners manual specified
justl 10W.30
Old Apr 21, 2009 | 09:30 AM
Bitburgslim's Avatar
Bitburgslim
Thanks for posting this, I have a 90 and was curious about whether real or synthetic would make a difference.
Guess keeping it real is where its at.
Old Apr 21, 2009 | 09:33 AM
Alan777's Avatar
Alan777
I prefer full synth, seems to work well in my 88. The engines do get hot on these, and synth can handle a lot more heat
Old Apr 21, 2009 | 10:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
90Z used dino oil, L98 also.
Syn in 92-up
Old Apr 21, 2009 | 10:42 AM
M.J.L.'s Avatar
M.J.L.
Synthetic is also good for causing leaks with it's cleaning detergents on sludged up engine internals.
Old Apr 21, 2009 | 12:26 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I can fix leaks. Sludge can shorten an engine's life considerably.
Old Apr 21, 2009 | 01:44 PM
M.J.L.'s Avatar
M.J.L.
I don't even know if mine has leaks. I have used castrol before and it supposedly gets rid of sludge...More market hype I presume.
Old Apr 22, 2009 | 06:00 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
When I switched my 85 to Mobil 1...the oil was extremely dirty inside of 1500 miles or so. I changed it...again super dirty in 1500 miles. After about a year of mobil 1 I could go longer without changing the oil due to all of the crap coming out of the motor. I did also have to fix a couple of oil leaks.
To Really strange argument
