Oil Leak
Old Apr 21, 2009 | 11:21 AM
coco1950's Avatar
coco1950
Default Oil Leak
Has anyone heard of using Blacklight Dye in your oil to find a leak. If so, where do you get it and how much should you put in the oil.
I can not find my leak. It is leaking on the passenger side all over my starter and exhaust pipes. I looked at the intake and valve covers but they are dry. I guess if what I heard about the blacklight dye,(if it works) it should show me the leak source.
Thanks !!!
Old Apr 21, 2009 | 12:24 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can get it at any decent auto parts store. Just follow the directions on the package.
Old Apr 21, 2009 | 01:56 PM
Targa86's Avatar
Targa86
For best results pressure wash the engine first then pour in the dye. Warm up the engine and let it shine!! Works great for power steering too.
Old Apr 22, 2009 | 12:37 AM
rodj's Avatar
rodj
Checked the oil pressure sensors at rear of block behind dist?
.Common for them to leak with age
Old Apr 22, 2009 | 02:25 PM
onedef92's Avatar
onedef92
I wouldn't recommend pressure washing if you've got an early, un-vented Optispark module distributor, though. You might get an unpleasant surprise.
Use Simple Green and paper shop towels to wipe down grimy areas.
To Oil Leak
