AC High Pressure Switch
Old Apr 22, 2009 | 08:31 PM
95VetteMan1's Avatar
95VetteMan1
Default AC High Pressure Switch
I need an AC High Pressure Switch, is there a certain color?
Old Apr 23, 2009 | 12:17 PM
SunCr's Avatar
SunCr
Assuming a '95, there is no High Pressure Switch. '90 and up use a Pressure Sensor. It's a 3 wire Thermistor with a 5 volt PCM reference, Return and Ground. Return is proportional to pressure with each volt being about 100 psi. PCM looks for a voltage increase from the Sensor when it drives the Compressor Relay. If it doesn't increase, it shuts down the system. It will also shutdown with high pressure or a voltage return at or greater than 4 volts. Should be a/c delco #15-5742 or: http://parts-catalog.acdelco.com/b2c/catalog_search.php
