1986 vette
Old Apr 25, 2009 | 07:26 PM
kent hastings's Avatar
kent hastings
2nd Gear
Default 1986 vette
Hi, couple questions, in a 4+3 vette do u just hit the button on the shifter to make it upshift? i was in 4th doing 70mph at 2900 rpm and it was telling me to upshift so i pushed the button and nothing happened. also under the drivers rear compartment i took out the plastic 'bucket' and under it was a weird contraption with hoses going into it, what could this be? thanks guys
Old Apr 25, 2009 | 08:48 PM
rodj's Avatar
rodj
You can command it/out of O/d if you are running in MANUAL mode.
By default, UNLESS you disengage O/d by pushing the buttom it will be in auto O/d mode every time you start.
The computer will automatically turn the O/d on when pre-programmed conditions are met; speed , engine temp , etc.
Hit the button before you drive off and you have complete man control over O/d. Can shift in / out of O/d whenever you want
Unit in rear is ABS pump and controls
Old Apr 25, 2009 | 09:28 PM
kent hastings
2nd Gear
i did not hit the button intill i was in 4th , [so it shoulda been in o/d mode] and it was telling me to upshift, but it dident upshift, so maybe the button is broke? thanks
To 1986 vette
