I hadn't driven the car for a few days and when I went to start it yesterday, the battery was completely dead. It seems like too soon for it to have died on its own. I got to thinking about what could have caused it and came up with the following: I have one of those cigarette lighter adapters for my I-pod. I had taken the I-pod out to put back in my other car but left the adapter in the cigarette lighter. Could that have drained the battery? Even though there was not an I-Pod attached, asking for power.
I unplugged my cig lighter until I fixed the power drain it was causing. If you have something plugged into the cig lighter yes it will drain. Its basically a switch and when you stick something down in it your switching it on.
Think about it, the lighter doesnt draw power and heat itself up, it gets it from the cig switch. Oh and its hot at all times.
No, it should not drain the battery if the Ipod is not plugged in. The only way would be if the charger had some sort of a ground issue, which you should have noticed when charging the Ipod. Unless you maybe somehow let the end of the charger touch metal when you left it? Otherwise you do not have a circuit.
Most every adapter, whether a 120v for the home or 12v in the car is using power, whether they are plugged into their respective device or not. I wouldn't leave anything plugged into a cig lighter.
If you want to be sure, just connect a meter inline at the negative terminal on your battery and measure the milliamps being drawn. Next, plug in your adapter and measure it...bet it goes up. Do tis with the key out and doors closed to avoid other draws.
I believe that it wouldn't. I leave my GPS plugged into my cigarette lighter and the battery doesn't die. Although the GPS is turned off. You may just have a dying battery that is on its last life. Try filling up the battery and giving it a trickle charge for a few days.
