I know this could go in the general cleaning section, but just thought I'd try here first as maybe someone on this forum has had hands on experience...
Looks like the lady friends '86 has sprung a leak - guessing heater core. It has that nice sick sweet smell and the carpets are wet.
So, that leaves me with 2 questions - first is a heater core a shade tree mechanic job?
And second - has anyone had any luck cleaning the carpets after a mess like this or do we have to bite the bullet and get new carpets? Really hate to have to do that as they appear to be in pretty good shape...
heater core is ''advanced shade tree''...still better than a shop with a kid trying to '' beat flat rate time'' on a car he's never been into before.
if your anti-freeze was old and full of crud, the carpets are permanently stained, toast...good antifreeze will eventually evaporate (several weeks), no smell, no stain... evap can be accelerated by an elec 'box' fan (or better) to a couple of days...get the car to a detail shop that can ''shampoo + vacuum dry" while still anti-frz soaked for best result.
Heater core is a real PIA job, most people will tell ya the part # 00001 meaning they built the rest of the car around the heater core, basically most of the dash has to come out unless your double jointed. I really wouldn't call it a "shade tree mechanic job". I think you can save the carpet but it will take a lot of sun and open windows to dry it out after you wet vac and get as much coolant out as possible. Good luck
The heater core is a BIG job, you have to basically pull the dash. As far as the carpet (I own a carpet cleaning company), pull out the piece that is soaked, along with the pad, and put it on a hard surface outside on a sunny day. Hose it down real good, LIGHTLY scrub with Simple Green (low residue cleaner) on trouble spots and thoroughly rinse with a garden hose, rinseing completely is the big thing here. Bake in the sun untill COMPLETELY dry (again a big thing). Re-install. The carpet nap is nylon, the backing is polypropelene, both are inert. They won't shrink or mildew. The Ozone in the air and the ultraviolet in the sunlight will act to freshen the carpet. The backing must be rinsed and dried too, or else the antifreeze or grease will wick back up into the fibers and will retain odors.
coolant washes right out of the carpet, it did on mine. Its 50% water after all. The heater core is not too bad but a shop will charge you $800-$1000 to install a $20 part Better off doing it yourself if you can.
Just give yourself an afternoon to get it replaced, and try to stay calm!
I see most of the Corvette places want $100 - $150 for the core. Autozone has one listed for $42 - any pros or cons about going either way?
Just after I bought my '88 IROC-Z a few years ago the heater core let go. I picked up a new unit from the local AC Delco store as I didn't want to have to do it again any time soon.
I took my time (several days) and got the job done with no real frustration. And yes I pulled the dash to get at some of the screws. Also I replaced both heater hoses, since I was "in there".
Afterward I mopped up all the fluid from the carpet and then hit it several times with a scented carpet cleaner. It still smelled a little "sweet" for a short while but the summer sun soon got rid of all odor.
The heater hoses are replaced via the engine compartment, correct?
My heater core is fine I think in my 89. I plan on draining and flushing out the coolant system via my garden hose. Would it be a good idea to pull the heater hoses and run some water through the heater core? I'm guessing run water in both hoses to flush it front and back?
Flush your heater core gently,real gently,too much hose pressure can pop it.
So, I'm guessing a water hose with the spicket turned full on is too much flow? And while on the subject, what about the radiator? I plan on removing that and flushing it as it has gunk inside on the fins.
Fred is spot on here. I work for a family owned commercial flooring contracting company and we have dealt with a lot of spills over the years. This advice is straight up correct.
