fuel pump?
Old Feb 4, 2002 | 10:03 AM
emsrescu's Avatar
emsrescu
Default fuel pump?
Not pumping. Changed the relay still not working. Checked the fuel rail and no pressure. I hear no fuel pump when the key is turned on. This is on an 88 and i have no clue how to check it out any ideas? :crazy:
Old Feb 4, 2002 | 01:18 PM
JonM's Avatar
JonM
Default Re: fuel pump? (emsrescu)
Check the fuel pump fuse
if its ok you most likely have a bad fuel pump.
Apply Voltage (12v) to terminal "G" the pump should run
This info taken from my 84 book
Old Feb 4, 2002 | 02:05 PM
emsrescu's Avatar
emsrescu
Default Re: fuel pump? (JonM)
cool i will give it a try.
Old Feb 4, 2002 | 09:49 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Has anyone else ever noticed, that when it is time to do a fuel pump replace job, the tank is ALWAYS full. :rolleyes:
Old Feb 5, 2002 | 09:14 AM
emsrescu's Avatar
emsrescu
Default Re: fuel pump? (Rob 91Z07)
she has a 1/2 tank now but, it's 18F out now with a windchill of 1F so it will wait for now.
Old Feb 5, 2002 | 09:25 AM
Tom Piper's Avatar
Tom Piper
If I remember correctly (I don't have my schematics at work) this is how it works:
When you turn the key on, power is supplied to the fuel pump through the fuse. Then, the ECM supplies to ground to the fuel pump to complete the circuit and the pump should run for two seconds. If the oil pressure builds up to 4 psi to close the switch to keep the pump running during that two seconds, the pump will keep running. If it the oil pressure does not build, the pump will quit.
The easiest way to check the pump would be to make sure the fuel pump fuse is ok and ground the negative side of the pump to see if it runs. If the pump runs this way, the pump is OK and the problem is in your oil pressure switch, ECM or wiring.
I don't know what year it started, but the security system can stop the pump from running -- I think GM calls it FEDS (Fuel Enable ???? System).
Tom Piper
[Modified by Tom Piper, 8:28 AM 2/5/2002]
Old Feb 5, 2002 | 12:13 PM
CFI-EFI's Avatar
CFI-EFI
SO WHAT!
The Corvette is one of the few cars where you don't have to deal with the gasoline to change an in tank pump. Besides, the less air in the tank, the less volitile air/fuel mixture to explode. There's nothing more dangerous than an "empty" gas tank.
To fuel pump?
