Dohc/sohc
Old May 7, 2009 | 04:42 PM
coorslight's Avatar
coorslight
Default Dohc/sohc
In 94 , did they make an LT1 in DOHC and SOCH, and if so , how do you know which you have?
Thanks Guys , love this site....
Old May 7, 2009 | 04:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
None, only OHV. Overhead cams were used on the LT5 in the ZR1s only, they were 4v DOHC motors. All the rest were 2v with one cam in the block.
Old May 7, 2009 | 05:10 PM
bb62's Avatar
bb62
Just to extend your comment. The LT5 in the C4 ZR-1 was the only production Corvette to EVER use double overhead cams. Every other V8, big block or small block since 1955, uses the one cam in the block.
Old May 7, 2009 | 07:43 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
you must be thinking about the rustangs.
Old May 7, 2009 | 08:03 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old May 7, 2009 | 08:44 PM
VetteFreak91's Avatar
VetteFreak91
Old May 8, 2009 | 07:12 AM
kalister1's Avatar
kalister1
Hey guys, lets have a Little respect for our Ford Brothers, when you talk about Rustangs use a capital R.
Old May 8, 2009 | 12:23 PM
slim jim 2's Avatar
slim jim 2
RUSTANG
Old May 8, 2009 | 11:44 PM
VetteFreak91
Originally Posted by slim jim 2
RUSTANG
They're gRRRRRRReaaaaaaat!
Old May 8, 2009 | 11:54 PM
Demonic85's Avatar
Demonic85
yeah they switched over to a single overhead cam design in '96. (A cam on top of each head). They are notoriously a pain the butt to take apart.
Old May 9, 2009 | 07:27 AM
rons85's Avatar
rons85
Yeah, and Ford's business case for making the change to the OHC motors made So much sense. Higher fixed cost (Much higher, as much as $400 per vehicle in some cases), less HP and lower torque than the motors they were replacing (at the time, anyhow). NO improvement in either economy or emissions compliance. Big changes required in all of the body structures to accomodate wider and taller moters, etc.
I guess ridding themselves of the "old school" pushrod motors was worth it. Whatever, the whole OHC thing Still hasn't resulted in anything positive, as far as I can see. Meanwhile the old pushrod SBC (granted in it's third incarnation now with the LSx designs) keeps on getting it done..
Old May 9, 2009 | 09:28 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Imagine the power if they install a DOHC in today's ZR1.
Old May 9, 2009 | 11:56 AM
ultraviolet70's Avatar
ultraviolet70
They don't need it, that's the reason they don't do it. With the LSx gen engines they designed a head that can flow as well as 4v DOHC heads can without the cost or complexity.
So I imagine the power and you know it's about the same.
Old May 9, 2009 | 12:39 PM
Demonic85's Avatar
Demonic85
Manufacturers claim the DOHC design improves the torque curve and improves throttle response. I own both and dont much of a difference.
To Dohc/sohc
