Y-Pipe
Old Feb 4, 2002 | 10:25 PM
metal480's Avatar
metal480
Cruising
Default Y-Pipe
Anyone happen to know how much it costs to have a Y-Pipe replaced on a 87 Vette?
Old Feb 4, 2002 | 10:26 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Re: Y-Pipe (metal480)
Front or Rear?
The rear is about $100
Will
Old Feb 4, 2002 | 11:34 PM
metal480's Avatar
metal480
Cruising
Default Re: Y-Pipe (flyinace2000)
Front or Rear?
I don't know which it is... it's a car thats for sale, which I haven't looked at yet.
That's for just for the part, right? If I buy this car I would need to take it somewhere to have it done since I currently don't have a place to work on it.
Old Feb 5, 2002 | 12:28 AM
CG77VETTE's Avatar
CG77VETTE
If it's only a bad "Y" pipe it will run anywhere from $150 to $200 installed. It all depends on how the pipe is installed (clamped = cheaper; welded = more expensive). You also have to consider the condition of the mufflers. If they are in poor condition, they will probably not be able to be reinstalled and you will need to replace the entire exhaust from the "cat" back. I would take the car to a reputable exhaust shop in your area that is familiar with Corvettes, they should be able to give you all the info you need. I would say that the complete exhaust system from the "cat" back could run anywhere from $600 for a stock replacement to $1,200 for a high end stainless steel system. Many Forum members run exhaust eliminators which any good shop can install for much less, but the car will also be much louder. It's your choice.
To Y-Pipe
