Hatchback with tint advice needed
Old May 12, 2009 | 11:29 AM
AustinJohn's Avatar
AustinJohn
Default Hatchback with tint advice needed
My hatchback is tinted and I'd like to keep it that way as the tint makes it difficult to for the curious to see what is in the hatch.
The problem - and here's where I need advice - is when I stow the top (red) it sets up a terrific reflection that makes it virtually impossible to see to the rear using the header-mounted rear view mirror.
I bought some black felt to wrap the top when it's stowed and that helped a little but wonder if anyone has found a solution (other than removing the tint).
Thanks in advance!
John
Old Oct 4, 2009 | 10:47 AM
AustinJohn's Avatar
AustinJohn
Four months later and lots of views but not a single reply and since I've seen other posts like this one that ask a question I'm interested in but never get any traction in the Forum, I'll follow up myself.
The black felt I mentioned helped a lot BUT was a headache itself as if wind caught it (and it usually did), then I had a second problem - "flying felt". So I bought the Mid America Motorworks Roof Panel Storage Bag which worked better but still there were reflections, especially at night.
So finally to the last alternative: I had a shop remove the hatch tint ($50, 45 minutes and a flawless job) and problem solved.
I wish I still had the tint as I agree it looks neat and adds to the "look" of the car but I feel safer night and day, can see to the rear sides better as well as the rear and I'm a happy camper. I've undoubtedly given up some UV and heat but that's a trade I'm willing to make. And the rear hatch cover is available when I've got something to hide.
John
Old Oct 4, 2009 | 11:32 AM
pianoguy's Avatar
pianoguy
Sorry nobody replied. Sounds like you found a solution, though - I'm surprised to hear that the bag also caused reflections.
Old Oct 4, 2009 | 11:34 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I did not see this before, but I would have told you to get one of those things that raise the hatch a couple of inches to allow air to flow though the cabin. I'm sure it would have helped your problem.
Randy
Old Oct 4, 2009 | 01:55 PM
IslandPirate's Avatar
IslandPirate
It's a Corvette!... just drive fast enough that you don't need to worry about what's BEHIND you !!
I'm kidding... sorta...
I just got a Vette and have a very dark tint in the hatch... I've noticed the same thing with the top stowed... but I like the tint. I may try that hatch-latch vent thingy... just changing the angle of the glass a tiny bit might make a huge difference in the reflection.
Old Oct 4, 2009 | 02:04 PM
AustinJohn's Avatar
AustinJohn
That's a nice looking car indeed!
John
Old Oct 4, 2009 | 02:47 PM
samsonb's Avatar
samsonb
Is the hatch tint factory? My 89 has it as well as the windows. I'm guessing so since I see alot of C4's with tint on the windows and hatch glass.
Old Oct 4, 2009 | 02:53 PM
AustinJohn's Avatar
AustinJohn
Josh - It's possible there was a factory tint altho I don't recall seeing a RPO for it. Mine - at least on the side windows - was aftermarket as the installer's decal was on the driver window with the installer's name and degree of tint. John
Old Oct 4, 2009 | 08:13 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Oct 5, 2009 | 06:03 PM
Steve59's Avatar
Steve59
I was thinking about removing the tint on my 87. I really don't like it, it make for terrible visibility.
My questions are: how did the removal affect the rear defroster stripes? Were they able to remove the tint without screwing up the rear window defroster? How do they remove the tint?
Steve
Old Oct 5, 2009 | 06:22 PM
AustinJohn's Avatar
AustinJohn
Steve
Steve - Mine was removed without any problem using steam.
I used a local family-owned tint installation company with loads of good reviews. The fellow who did the work told me he would know within a minute how hard it would be. He said one of the "hints" of a hard removal job is any bubbling or separation in the tint and mine had none (in fact they couldn't understand why I wanted to remove it as it looked so good).
The tint all came off in one piece and it actually took them longer to clean the glass than to remove the tint. I don't know how to know for certain there was no damage except to test it once the weather turns cold enough (which in Austin may not occur until January) but it looks fine and he said there wasn't any damage.
John
Old Oct 6, 2009 | 06:09 PM
Steve59's Avatar
Steve59
Thanks for the info. Never would have thought of using steam.
Steve
Old Oct 6, 2009 | 11:40 PM
samsonb's Avatar
samsonb
How do you remove the tint residue? The PO had tint on the windshield that I had removed. And when the windshield fogs, it doesn't fog where the tint was. Or if I spray Windex on the windshield, it is still clear where the Windex was.
Old Oct 7, 2009 | 07:40 AM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
I also just came across your posting.
Too bad you already resolved the "problem" by removing the tint. Come the summer, you'll again wish to have the window tinted.
Anyway, I know exactly of which you speak. The bright yellow roof panel in the hatch caused a lot of reflection on the rear glass, tint or not.
So I went to my nearby auto upholstery business and had them make a custon black leatherette bag for it. Velcro straps keep the backside flaps in place and it stows neatly with the corners cut out so to fit the holders.
Works well, and eliminated all the glare.
I use the hatch lifting device all summer, but that is for ventilation moreso than reflective glare reduction.
Old Oct 7, 2009 | 08:56 AM
flynn508's Avatar
flynn508
I also just saw your post, and have the same problem, and my top is bronze tint and not paint, but there is still some distortion there; not as bad as with a painted top though I'm sure.
To Hatchback with tint advice needed
