Alternator, Time to replace?
Old May 18, 2009 | 03:19 PM
95AquaVette's Avatar
95AquaVette
Default Alternator, Time to replace?
I still have the original alternator on my 95. It now has 73K on the odometer. I have not noticed any symptoms yet but, would it be cheap insurance to replace it at this point. I am starting to worry that it may take a dump on me soon. Also how hard of a job is it to replace the alternator on a 95 LT1?
Tony
Old May 18, 2009 | 03:38 PM
jimg's'93's Avatar
jimg's'93
I wouldn't replace it 'till it dies. You can also have it tested at most any of the chain parts dealers.
As for removal, you simply remove the serpentine, disconnect the alternator and remove the mounting bolts.
Old May 18, 2009 | 04:09 PM
CAJUN C4's Avatar
CAJUN C4
I agree...It could go another 73K Mi.
Old May 18, 2009 | 04:41 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
My '93 has 84,000 on it's alternator and the car is running fine. If it ain't broke, don't fix it.
Old May 18, 2009 | 06:10 PM
slim jim 2's Avatar
slim jim 2
if its not broke don't fix it
Old May 18, 2009 | 11:17 PM
cedrop's Avatar
cedrop
No guarantee a new one will not fail.
I replaced my 91 with a NAPA lifetime warranty,cuss it stopped.
The replacement threw the pully after about 2k, replaced it again when it started making a whining noise. The 3rd one is on for about 6-7k now , hopefully it will last another 40-50K.
Thankfully the change out is easy
Old May 18, 2009 | 11:53 PM
jfb's Avatar
jfb
My 74 vette I bought new and sold it 14 years later with 214k miles and the original alternator.
My 87 vette has 230k and is on its 3rd alternator and I think this last one has about 100k on it.
Old May 19, 2009 | 01:04 AM
shbbykins's Avatar
shbbykins
mines on around 102k. if you are a handy person you can rebuild the damn things yourself
Old May 19, 2009 | 07:04 AM
Doug 87L98's Avatar
Doug 87L98
I replaced one on my 87 when it failed. It lasted less than a year!
If it ain't broke don't fix it! Keep an eye on you're gauges. A failed alternator shouldn't leave you stranded. The battery light should come on in plenty of time to get you somewhere safely.
Old May 19, 2009 | 08:05 AM
runner140*'s Avatar
runner140*
Tony
An old Army saying: "Don't fix it if it aint broke". I've got over 160,000 miles on my alternator and wouldn't think of changing it until its gone.
Old May 19, 2009 | 08:50 AM
Muffin's Avatar
Muffin
The first law of wrench turning.
Old May 19, 2009 | 12:47 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The voltage regulators usually crap out before the O.E.M. Delco alternators. Are you getting flickering dash lights or any other suspect symptoms?
Old May 19, 2009 | 01:40 PM
65747785's Avatar
65747785
If you don't have any problems with it, leave it be. Heck, you could replace it with a new or rebuilt one and it go out in a year or 2. Like others have said here, if it ain't broke don't fix it.
Old May 19, 2009 | 01:55 PM
flynn508's Avatar
flynn508
couldn't agree more; they can go on forever if they were built particularly well; some new ones aren't wound tight, and will fail early. If you got a good one, it could last forever.
Old May 19, 2009 | 03:29 PM
95AquaVette
Reason I posted the question is a may be getting a job in Florida and will probably have to drive the car down there from Philly. I just don't want to have it take a dump somewhere along 95 where the nearest parts place is who knows where.
Old May 19, 2009 | 04:09 PM
89er's Avatar
89er
Heat is what kills the alternators on C4s so if it runs cool it should be good for a long time.
Old May 20, 2009 | 12:14 AM
Doug 87L98's Avatar
Doug 87L98
If that's what you are worried about, buy one and take it, and the tools to change it, along with you. Leave the original one right where it is!
Good luck with the job.
Old May 20, 2009 | 08:46 AM
65747785's Avatar
65747785
One habit I got into with all the cars I've had over the years is, I replace the starters and solinoids. Especially if they're dirty, rusty and the miles on the car are over say 50K, 60K miles. The reason I started doing this about 10, 15 years ago is, I don't know how old the starter is and how many starts it has on it. And when it might strand me somewhere. For around 50 bucks it's good insurance to start out with a used car and a new starter.
To Alternator, Time to replace?
