Normal water operating temp
Old May 21, 2009 | 04:57 PM
Havelock's Avatar
Havelock
3rd Gear
Default Normal water operating temp
What should the normal water operating temp be on a 93. What should the max be. On runs in traffic in Florida the gauge is enough to make me nervous. Been as high as 221.
Old May 21, 2009 | 05:03 PM
Muffin's Avatar
Muffin
That's about right. These Glass Wonders are built to run hotter.
Old May 21, 2009 | 05:24 PM
SunCr's Avatar
SunCr
Normal for any vehicle that uses an electrical fan(s) is whatever temperature that grounds the Relay(s) and from there a 5 to 6 degree drop. If it doesn't drop or climbs with the fan(s) running, there's a cooling system problem.
Old May 21, 2009 | 05:54 PM
blben4's Avatar
blben4
That's about normal, my '95 runs 200 to 230 in traffic.
Old May 21, 2009 | 05:55 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Don't worry, the "check gauges" light will come on when it gets too hot.
Old May 21, 2009 | 06:15 PM
iamfine2's Avatar
iamfine2
I concur.
My 1995 with the a/c on runs between 195 and 230.
I use the digital guage on the dash to be sure, the analog tends to read higher.
Old May 25, 2009 | 07:17 PM
Havelock's Avatar
Havelock
3rd Gear
Thanks for the info, it's nice to have company
Old May 26, 2009 | 08:18 AM
RedVette84's Avatar
RedVette84
Some of the members have had luck with lower temp thermostats,the wetter agents that lower coolant temps and manual switches to kick their cooling fans on. But I agree that this is the normal operating temp for the C-4. Of course you could check in front of the radiator for debris also.
To Normal water operating temp
