ignition problem
Old May 21, 2009 | 06:23 PM
King_Tut's Avatar
King_Tut
3rd Gear
Default ignition problem
My 87 is havin some trouble starting/turning off. The electrical part of the ignition is still good so i think something mechanical is wore down and broke so its not catching and/or turning something. Any ideas?
Old May 21, 2009 | 10:16 PM
jfb's Avatar
jfb
The ignition switch is mounted behind the dash and there is a rod from the ign lock down to the ign switch which activates the switch. I would recommend you look at this rod and its connections on each end of the rod and the tightness of the ign switch mounting.
