Hi volt message
Old May 22, 2009 | 04:50 PM
Allieboy's Avatar
Allieboy
Default Hi volt message
Top off and I'm on my way home looking to enjoy the weekend then i get a hi volt reading on the gauge.
i had about an hr drive so i called the mechanic and he said it could be a bad gauge or the alternator. It was reading with accessories on anywhere from 12.6 - 17.1. most of the time it was in the 13's. i put it in neutral when it got too high.
its probably the alternator but is there anyway to check it before just replacing. i have a fsm but its always in another language to me.
any suggestions would be great.
thx and enjoy ur weekend.
Old May 22, 2009 | 05:03 PM
Allieboy's Avatar
Allieboy
also after i took the car out of storage sys was flashing but it stopped after a little while.
Old May 22, 2009 | 10:16 PM
Weav's Vet's Avatar
Weav's Vet
I can't help because I'm an electronic dummy but here's a bump for ya.
Weekends can be kind of slow around here especially long ones. Good luck!
Old May 22, 2009 | 11:10 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default voltage
13's are good. Might be regulator inside alternator. Good Luck.
Corvette Mike
Old May 23, 2009 | 02:47 AM
85 500 horse's Avatar
85 500 horse
I can't think of anything but an alternator that would cause the problem you're experiencing. I would check the battery with a multimeter. You can get one really cheap at Radio Shack.
With the car off, the battery should read about 12V. When it's running, if it reads more than 14.5V or less than 13V, it's probably the alt.
Old May 23, 2009 | 06:24 AM
Paul Workman's Avatar
Paul Workman
Default Voltage regulator...
Could be your gauge or a bad ground (your FSM will help you find your ground lug(s). But, like da man said, a VOM across the battery posts will tell the tale: At quiescence after sitting a while w/ engine off, 12.8VDC ± .3 at room temp is "normal". After starting the (cold) engine, the voltage across the battery should be a steady 14.7 ± .5 (ideal), and drop down to around 13.6 when it is fully charged and good and warm.
As a rule of thumb: (cold engine) reading is typically 14.7 volts (measured with a volt meter across the battery terminals) is ideal. After being charged for some time and when the the under-hood temps rise, 13.5 is about normal. Below say 13.2 or above 16 when being charged, and you might start thinking "voltage regulator" - which is built into our alternators.
P.
To Hi volt message
