What a PITA!! I decided about 8pm that I was going to go ahead and lower my 92. I got it up in the air, the sway bar disconnected and steering ball joints, started to get the lower ball joints off and SMASHED my thumb with a brass hammer...I CANT GET THEM OFF! I'll start again in the morning Anyone have any suggestions ?
I have 2 ball joint pullers/seperators and both of them are too damn small. I'll have to go find one in the mornin. I just replaced the ball joints on my truck last week so I might as well replace these while I've got it apart.
yeah thats what i'm thinking i'll just got the separator fork thingy and beat the hell out of it and be done with it.
There are different size forks.
Be forewarned that you'll most like destroy the dust covers on the ball joints using the fork unless they've been replaced recently. Then you'll have to take it and have a new one installed. The good joints are 100.00 a piece. Most of the parts stores rent the separator. Good luck
started to get the lower ball joints off and SMASHED my thumb with a brass hammer...I CANT GET THEM OFF! I'll start again in the morning Anyone have any suggestions ?[/QUOTE]
From: My Give A Dams Busted The Bend Me Over State N.J
I had the same issue . I jacked the control arm back up. Then took my bracket from something I took off the car. lol ac i think. I placed it in the ball joint some how that when i lowered that jack it kept the ball joint straight and popped it out.
Got the ball joints out in like 5 mins lol maybe I just needed to walk away for a few...almost got it all finished I had a function to do today so I didn't get to spend too much time on it, but i think i'll have it finished tommorrow and I'll post some pics.
I finished it,I will post pics later it is raining here now. I couldnt get the spring out and had to cut the shims in place as well. It dropped the front like almost 2 inches it looks good and i dunno bout lowering the rear i ike the way the stance is now, it looks more aggresive lol and it doesnt look like a volkswagon. One thing I will say about lowering a C4 is "I WILL NEVER DO IT AGAIN, WHAT A PITA!"
Yes I've had hangovers and as a mater of fact I had one this morning when I was doing this ! I have no idea why it wouldnt come out it just wouldnt and if I could get all of the old shim out without taking the spring out and wrestling it back in and still accomplish the same objective why does it matter?
Man I want to lower my 95 but every thread I read on this ends in the same result. PITA...
It looks like it's not a job I want to tackle. I keep putting it off. I think I might hit up my buddy at the Vette shop for this one...
If you can get a shop to do it for say....under $500 i say go for it.
If not then just do it yourself. The job itself isn't that hard, it's the minor complications that each car and person has that are throw at us.
If you REALLY take your time, and make sure you do it right you won't be disseminated. I had to get mine done in a weekend and i felt very rushed, ended up running into some problems making it much worse time wise....
