GPS Install
Old May 23, 2009 | 02:31 PM
89 Vett's Avatar
89 Vett
Default GPS Install
I grew tired of my GPS, iPhone and radar detector all suction cupped to my windshield. Finding no solutions available, I set out for my own fix.
With all the parts removed I decided the best looking solution would be for the GPS to sit at the top where it could be viewed easily in front of the two center vents.
I cut the plastic and wood trim to make room for the GPS. The notch at the bottom is for the GPS release button. The hole drilled to the right of the stereo hole is for an aux jack. I routed an edge into the backside of the trim around the warning light display. This allowed me to put a clear plastic window there.
A replacement brace for the GPS to be mounted (and screwed) to. Once cleaned up this was painted black and the edges of the plastic sanded down.
To insure the proper amount of air still flowed into the cabin, I opened up the outside edges of the vents to allow more air flow.
Completed image. The GPS is still removeable when needed (it can run on its own internal battery). The iPhone is bolted to the clear plastic window I installed via a cut down piece of Griffin's Window Seat mount (intended for use on the windshield). I installed the aux jack on the right of the stereo and a USB charging port on the right hand side of the dash. The USB also connects to the Alpine stereo. I don't have the electronics hardwired to power yet and currently it plugs in using the 12V plug. Also picutred here is the wireless remote for the stereo on the steering wheel and the Viper 5301 keyless/remote start key fob and Alpine X001.
Old May 23, 2009 | 02:40 PM
89 Vett's Avatar
89 Vett
More pictures at http://forums.corvetteforum.com/memb...s-gps-add.html
Old May 23, 2009 | 02:43 PM
Noobster's Avatar
Noobster
From: My Give A Dams Busted The Bend Me Over State N.J
If that was Carbon fiber it would be hot . But it looks good.
Old May 23, 2009 | 02:45 PM
Brett Richmond's Avatar
Brett Richmond
Looks Great, I made a bracket to mount my GPS beside the instrument panel.
Old May 23, 2009 | 03:05 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Looks great, but I don't have that talent so I took the easy way out.
Love the way yours looks
Old May 23, 2009 | 03:45 PM
89 Vett's Avatar
89 Vett
What is that to left of your center vents and right of the instrument panel? Garage opener?
Old May 23, 2009 | 04:11 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
You guessed it!
Old May 23, 2009 | 05:53 PM
Goldcylon's Avatar
Goldcylon
Hmm while I like the look of the carbon fiber I am not sure if that would go well with the Cognac interior. Maybe
Old May 23, 2009 | 11:00 PM
mrmtrtrnd's Avatar
mrmtrtrnd
That's a good idea and really nice work. Job well done
Old May 24, 2009 | 09:21 AM
convas's Avatar
convas
Very nice job.
Old May 24, 2009 | 09:41 AM
jsls0130's Avatar
jsls0130
Great job.
Old May 24, 2009 | 09:55 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
very good job.
Old May 24, 2009 | 10:40 AM
jimmers's Avatar
jimmers
Very well done!
Old May 24, 2009 | 09:10 PM
ultraviolet70's Avatar
ultraviolet70
Maybe a silly question, but don't iphones have true built in GPS? And if so why do you need both on the dash?
Old May 25, 2009 | 05:44 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
looks good
Old May 26, 2009 | 12:12 AM
89 Vett's Avatar
89 Vett
I have the first generation iPhone which doesn't have the GPS... even if it was the 3G, a dedicated GPS like Garmin or Tomtom does a much better job.
This GPS has an audio jack and an SD slot where it could be used as a media player as well. I didn't really have any need for that, but I am routing the sound to a cheap amp that powers the two 4x6 speakers in the dash. Those speaker holes weren't used, so now I can actually hear turn directions on the interstate while the top is out and I'm driving... well, let's say a 'little' over the speed limit. :o
Old May 26, 2009 | 08:21 AM
RedVette84's Avatar
RedVette84
Looks good. Though I wouldn't mind seeing how it would look in carbon fiber also.
To GPS Install
Old May 26, 2009 | 09:23 AM
89 Vett's Avatar
89 Vett
Actually... what I'm considering is taking all the trim panels off and sanding and sealing them. Then having them painted the same metallic blue as the car.
Old May 26, 2009 | 11:54 AM
rickneworleansla's Avatar
rickneworleansla
Better hope they launch some new satellites soon..
http://blogs.zdnet.com/mobile-gadgeteer/?p=1799
Old May 26, 2009 | 06:32 PM
ultraviolet70
Gotcha'
And BTW the install does look nice and I especially like the feature you mentioned installing in this post about the dedicated amplified speakers for the TBT directions very.
