hard shifting
Old May 29, 2009 | 05:00 PM
VinceC4's Avatar
VinceC4
Default hard shifting
Okay heres' the problem, I am having a hard time shifting into first..the clutch was replaced about 15,000 miles ago. The master and slave replaced about 5,000 miles ago. If I pump the pedal it will shift easily, is it posssible I have some air in the line?..the clutch seems fine most every other time..no slipping or anything like that. by the way the fluid level is fine. I have to press it all the way to the floor for it to act normal.
Old May 29, 2009 | 05:23 PM
RedVette84's Avatar
RedVette84
I had a similar problem - my slave cylinder was going and there wasn't enough hydraulic pressure to shift. I replaced the clutch master cylinder also. I was shifting with the pedal to the floor and eventually couldn't shift.
Old May 29, 2009 | 05:36 PM
VinceC4's Avatar
VinceC4
Oh no I hope it's not the slave..what a bitch to change..
Old May 29, 2009 | 05:59 PM
Swift_Striker's Avatar
Swift_Striker
had same problem, replaced slave made things better but not 100%, still needed to pump sometimes. Flushed the clutch hydraulics and bled them using my local auto stores 1 man flush system and no problems anymore
To hard shifting
